Faint 'machine gun' sound from my 2001 2.5 V6
Old Sep 28, 2007 | 07:36 AM
bigdreams05's Avatar
Default RE: Faint 'machine gun' sound from my 2001 2.5 V6
Can the car still rev all the way up the rev line? Can it easily get to 6000rpm or have you lost some power? Might be a million things. Anything from bent rods to bent valves to a transmission problem. You have to be more descriptive. Where is the sound coming from? A small video clip maybe?
Old Sep 28, 2007 | 08:52 AM
If it doesn't do it in neutral then I'd pin-point at the tranny obviously. Do this: Put it in second with the clutch disengaged and rev it. If it doesn't knock, then the problem might be with the pressure plate. A bit more specifically, does it do it a specific speed? If you get a little vibration as well, then it might be a misaligned drive-shaft. Common problem with the X-type. I give you this link, and I had to travel all the way back to April to find this. LOL! You have 28 pages to find problems similar to yours. As you can see, it's a highly covered issue.
https://www.jaguarforums.com/m_4926/tm.htm
Old Sep 28, 2007 | 09:39 AM
Cadillac's Avatar
Well, it might be a bad cat despite no poor accleration [&:]
2001 White XJ8
Feb 25, 2021 05:02 PM
picard
Oct 12, 2015 11:56 AM
hamilton7550
Sep 24, 2015 08:43 PM
Roger Mabry
Sep 15, 2015 09:22 AM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
