flickering lights
Old Apr 24, 2011 | 02:12 PM
Disco stu55's Avatar
Default flickering lights
My cars interior lights are flickering....like teh guage lights and console lights? any ideas?
Old Apr 24, 2011 | 03:46 PM
Cambo's Avatar
The flickering goes away when you give it a rev?
Do the headlights flicker too?
If so, positive battery cable to the fuse box, maybe a bad connection.
Maybe...
Old Apr 24, 2011 | 03:59 PM
Thermo's Avatar
Veteran: Navy
Disco, is it all of the lights that dim with the dimmer switch, or is it all of the lights? If it is only those that are controlled via the dimmer, I would be looking at a loose plug on the headlight switch assembly or a plug close to there. IF it is all of them, I would be looking at a bad fuse or the wire running from the fuse to the headlight switch.
Old Apr 24, 2011 | 04:32 PM
fabfive's Avatar
If I keep the dimmer knob on the lowest setting, the lights start flickering noticeably, if I then tap it a little higher all is well and no more flickering. It has always been for me.
Old Apr 24, 2011 | 04:53 PM
MeatBag's Avatar
Funny, I noticed the other day that the dimmer seems only to want to be All-on-Bright, or all low-n-flickery. Inside lights (all of em) only. I turned it back up and I'm leaving it alone. They don't flicker now, but that dimmer seemed to lack a middle level of brightness.
Old Apr 24, 2011 | 10:19 PM
aholbro1's Avatar
Check grounds. Different era, different car...I realize...but they do all seem to flicker, now, don't they?
https://www.jaguarforums.com/forum/x...witches-53109/
Jpav27
Jul 31, 2022 06:43 AM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
giandanielxk8
Sep 6, 2015 07:21 PM
Mosers63
Sep 6, 2015 02:53 PM
