Found a really nice video install in my car today
Old Nov 9, 2014 | 03:03 PM
3lvis's Avatar
Default Found a really nice video install in my car today
So I was removing my cassette player today to do that AUX input mod and saw some video cables and started tracking them to find the other end.
Nav removed:
Behind nav:
Tucked away in over head console:
Inside nav:
Forgot to take a picture of those two plugs that went to the boot. One seemed to be for remote and the other one for power, video and audio.
Old Nov 11, 2014 | 05:05 PM
Skinny's Avatar
Is this a mod from a previous owner, or actual cables belonging to the nav-assembly?
Old Nov 11, 2014 | 05:12 PM
3lvis's Avatar
Mod from a previous owner. I haven't heard about anyone who has Audio/Video cables connected straight to nav unit.
Today I connected a car DVD player to it and connected that little white wire to ground which overrides TV signal. Picture and sound quality is very good, only thing is that it's black and white but when watching a movie you forget about that quickly.
Oh and when you switch that system on it's possible for a passenger to watch a movie while the car is moving, which isn't possible with TV feature.
Old Nov 11, 2014 | 06:00 PM
MiamiTVR's Avatar
Would that have been for a backup camera?
Old Nov 12, 2014 | 01:08 AM
3lvis's Avatar
I don't think so. No need for a sound and remote for a backup camera.
Old Feb 13, 2015 | 04:58 AM
x_type_lpg's Avatar
any chance of a photo of the back of the board that has the wires connected? the small daughter board on the rhs is for teletext, its possible to feed RGB into this but you have to select tv and then text to view it. the square chip in the top lhs is a TDA8842 this has an audio output and a vidio out and in that could be where the connections are made
Old Feb 13, 2015 | 07:25 AM
3lvis's Avatar
I forgot to upload 1 photo. If it helps with you with a project or something then I can take more photos but if not then I would prefer not to take it apart again as I have a DVD player already connected to it.
I get a picture and sound if I open the TV image, no need to click on teletext. If powered up it also allows to watch a movie while driving which isn't possible with factory TV.
Old Feb 13, 2015 | 09:17 AM
x_type_lpg's Avatar
looks like the wires are teed into the ribbon cable. that feeds to the display panel.
Old Feb 14, 2015 | 06:11 PM
x_type_lpg's Avatar
mod'ed mine and now have av input. was quiet simple apart from the audio feed. the board has a single output that is linked under the ribbon cable socket to feed the L and R side speakers.
I did not cut into the cable I un-soldered the socket and cut the track between the two pins and then put the socket back. I also used a 4 pole relay so only had to fit one.
I'll produce a "how to" guide soon.
I get full colour on mine, you have to use the tv settings to set the region so that the board is programmed to the tv system so it can decode the signal.
Old Feb 14, 2015 | 07:35 PM
3lvis's Avatar
Color would be nice, do you get it only if you select a certain region?
Old Feb 15, 2015 | 04:49 AM
x_type_lpg's Avatar
each country seems to have a different tv system uk uses PAL USA uses NTSC France uses SECAM, not sure what system you use. JAG allows the region/country to be set from the TV screen. this then programs the chip in the tv part of the display to decode the video signal. the mod intercepts the signal between the two parts of the chip to allow a video signal to be inserted into the part of the chip that decodes it. if the country/region is not set correctly then you tend to get BW and not colour. try changing the setting and see what you get.
Old Feb 15, 2015 | 05:55 AM
3lvis's Avatar
Thank you so much, changed region and now I have color too.
Old Feb 15, 2015 | 08:55 AM
x_type_lpg's Avatar
I Got one of these
http://www.ebay.co.uk/itm/2216227662...%3AMEBIDX%3AIT
allows movies and music to be played from mem stick and has input for rear view camera, not sure if the DVB-t is the same in your area.
Old Feb 24, 2015 | 12:59 PM
x_type_lpg's Avatar
you say your screen allows the picture while the car in moving? must be another cct mod on the board. any chance of a picture of the board with the small square daughter board out of the way.
Isoruku
Jun 19, 2020 12:54 PM
rvdz
Dec 7, 2019 06:42 AM
MrMellor
Aug 29, 2017 08:06 AM
martybmw
Aug 31, 2015 10:15 PM
souldoubt
Aug 25, 2015 08:15 PM
