Front door handles need adjustment??
Old Jul 27, 2011 | 07:30 PM
Niens2000's Avatar
Default Front door handles need adjustment??
I hope someone can guide me to a solution to this issue. When I try to open the front doors the handles seem to be engaging the mechanism only at the very top of the pull. Sometimes I have to try three or four times to even get the door open. The rear door handles engage at about a quarter of the pull. Can this be an adjustment issue. If so is it something I can do without taking the door completely off the car? Any help/advice would be greatly appreciated.
Old Jul 27, 2011 | 08:06 PM
motorcarman's Avatar
Here is a TSB that describes your fault.
bob gauff
Old Jul 28, 2011 | 05:21 PM
Niens2000's Avatar
Thanks for the TSB info. Since I'm not the original owner will the dealer still cover it?
Old Jul 28, 2011 | 05:41 PM
Brutal's Avatar
Originally Posted by niens2000
thanks for the tsb info. Since i'm not the original owner will the dealer still cover it?
they wouldnt cover for the 1st through the 8th only the 9th owner and past....really. A "tsb" is not a recall and its out of your pocket to fix it, also there is a repair that involves no parts or $$$$$. The rod goes into a grey and white square clip that locks it. Pull the white put back alittle to unclip the rod so it moves freely. Now pull up slightly on the exterior door handle to "preload" the assembly and push the white lock back down to lock the rod in place. Latch the latch without closing the door and pull up on the handle to check your work. If okay then close it back up. If not do it again till you get it to unlatch without u=pulling the handle all the way up. The other side will be much faster and easier
Old Jul 31, 2011 | 02:54 PM
Niens2000's Avatar
Well guys I worked on it this weekend, did what Brutal suggested and it worked like a charm. Thanks, I'm planning to do the other side next weekend.
Old Aug 1, 2011 | 11:54 AM
Brutal's Avatar
Thanks for the thanks rob and glad you reported back for others. See we jag dealers techs arent all asssholes now are we...........
Dz1rfj
Jul 17, 2018 10:29 AM
XJsc-guy
Nov 23, 2015 01:56 PM
Dz1rfj
Sep 16, 2015 03:44 PM
hoodun
Sep 7, 2015 07:02 PM
bdboyle
Sep 4, 2015 06:16 AM
