Fuel gauge problem
Old Apr 26, 2009 | 11:32 PM
Gunz80's Avatar
Default Fuel gauge problem
hi it's long time...I just got baby.
pressure....haha
anyways....
I just notice that even I put full of gas, gauge shows me it's at middle....
after an hour drive....it show me full...
Is there anything I can do it myself?
I am scare to go to dealer...
Old Apr 27, 2009 | 07:18 AM
Thermo's Avatar
Veteran: Navy
Gunz, first off, there is part of the fuel level circuit that stabilizes the level. This is called the anti-sloshing circuit. So, if you fill the vehicle with the key left in the RUN position (motor running or not), you will see what you are experiencing. Whenever filling the vehicle, make sure the ignition key is in the OFF position. This resets the anti-sloshing circuit and will give you an accurate indication upon starting the vehicle.
If you are turning the car completely off when refilling the vehicle, then odds are you have either a circuit fault with the anti-sloshing circuit or your float in the gas tank is sticking, leading to the problem. To check the anti-sloshing circuit, you need a 256 ohm, 128 ohm, and a 10 ohm resistor. You will then need to unplug the cable going to the fuel tank. Then, you plug the resistors into the plug one at a time and when you connect the 256 ohm resistor the level should read full, the 128 ohm resistor will make it read 1/2, and the 10 ohm resistor will make it read E. As for checking the float for smooth operation, this is going to involve dropping the fuel tank and then pulling the fuel level float out and checking it for smooth operation. Not a hard job, but not a simple 5 minute fix either.
Old Apr 28, 2009 | 09:47 PM
Gunz80's Avatar
thanks!
it sounds tricky. but I will see what I can do...
thank you.
Old Apr 29, 2009 | 05:06 PM
survey_sez's Avatar
i have the same problem. refill the tank with ignition off. start car and guage is very very inaccurate. takes a day or two sometimes to read full.
Old Dec 8, 2009 | 11:19 AM
rhriczko's Avatar
I have the same problem... I noticed the guage was fine until I let the gas get too low and the light came on telling me I need fuel. Does anyone think this could contribute to the problem?
Old Dec 8, 2009 | 01:28 PM
The Chris X's Avatar
Had similar issues a few years ago. Dealer replaced the fuel sending unit under warranty.
Old Dec 8, 2009 | 04:46 PM
Tracus's Avatar
Mine has a problem too, but is stable. When full shows 90% full but I am used to it now.
Old Dec 8, 2009 | 06:16 PM
Thermo's Avatar
Veteran: Navy
Tracus, if your gas gauge is reading low, then it is almost always a problem with the level sending unit in the gas tank. Unfortunately, the only fix for that is dropping the fuel tank and putting in a new sending unit. Sounds like it isn't off by too much. So, you can either live with it for the moment or spend an afternoon putting in a new one. Not a tough job, but I would highly recommend running the car as low as you dare on gas and then change it. The less gas in the tank, the easier the job is. It can be a pain trying to keep a tank fairly level when you have liquid moving around inside of it. Not to mention much lighter.
Old Dec 8, 2009 | 07:26 PM
Colt's Avatar
Banned
I had same problem..Needed the fuel tank sending unit replaced..All better now.
Old Jan 27, 2010 | 08:46 AM
gbrutschea's Avatar
we have this but only intermittant when the car is empty before refilling. gas does tend to varnish on metal. my wife could not figure out wht her car would only take 1 gallon of gas. I had just filled it for her the night before.
Old Jan 28, 2010 | 05:37 PM
survey_sez's Avatar
for some unknown reason mine has repaired itself. for those of you experiencing problems i would recommend tolerating it for as long as you can. and see if it eventually fixes itsef. i think mine behaved badly only for a few months. perghaps something imechanical in the fuel sensing mechanism is prone to 'sticking'?
toronadomike
Jan 22, 2026 10:13 PM
jdzubas
Oct 4, 2015 09:14 AM
alpecsa
Sep 7, 2015 11:55 AM
AL NZ
Sep 4, 2015 08:39 PM
Bcrary3
Sep 3, 2015 03:48 PM
