Fuel pump malfunctioning - X-Type 3.0
Hello,
I have observed lately that my x type sometimes jerks on the road, my mechanic informed me the problem is with the fuel pump. So i ordered this unit: Petrol Fuel Pump In Tank For Jaguar X Type & S Type 2.0 2.5 3.0 4.0 from Amazon.
I have since replaced the in tank pump, and few days later, i am already noticing the same behavior, what am I getting wrong? any pointers please?
regards,
Nbewafaa
regards,
Nbewafaa
It is possible that the problem may be a clogged fuel filter but I would recommend you read the posts in the links below. In the first post try Thermo's recommendation to get the system to set a code. The poblem maybe anything from a loose connection to the incorrect gap on the spark plugs. It will be necessary to eliminate each cause one at a time.
https://www.jaguarforums.com/forum/x...riving-172706/
https://www.jaguarforums.com/forum/x...er-load-93040/
https://www.jaguarforums.com/forum/x...-speeds-10567/
Hello,
regards,
Nbewafaa
regards,
Nbewafaa
Boxman
Nov 16, 2016 03:05 AM
