Fuel pump malfunctioning - X-Type 3.0
Old Nov 22, 2016 | 08:02 AM
nbewafaa's Avatar
Default Fuel pump malfunctioning - X-Type 3.0
Hello,
I have observed lately that my x type sometimes jerks on the road, my mechanic informed me the problem is with the fuel pump. So i ordered this unit: Petrol Fuel Pump In Tank For Jaguar X Type & S Type 2.0 2.5 3.0 4.0 from Amazon.
I have since replaced the in tank pump, and few days later, i am already noticing the same behavior, what am I getting wrong? any pointers please?
regards,
Nbewafaa
Old Nov 22, 2016 | 09:36 AM
Nbewafaa,
I've moved your question from General Tech Help to X-Type forum. This is the place to post technical questions about your model.
Old Nov 22, 2016 | 10:59 AM
avern1's Avatar
It is possible that the problem may be a clogged fuel filter but I would recommend you read the posts in the links below. In the first post try Thermo's recommendation to get the system to set a code. The poblem maybe anything from a loose connection to the incorrect gap on the spark plugs. It will be necessary to eliminate each cause one at a time.
https://www.jaguarforums.com/forum/x...riving-172706/
https://www.jaguarforums.com/forum/x...er-load-93040/
https://www.jaguarforums.com/forum/x...-speeds-10567/
Old Nov 23, 2016 | 07:24 AM
swingwing's Avatar
Originally Posted by nbewafaa
Hello,
regards,
Nbewafaa
Yikes. You spent a lot of money for a pump and installation labor. What if your problem was caused by an inexpensive, easy to install fuel filter? I've learned to start with the basics; your mechanic tell you what the fuel pressure was before you ordered the pump?
Bulldog15
Jan 2, 2017 07:22 AM
jeffp634
Nov 30, 2016 01:42 PM
Boxman
Nov 16, 2016 03:05 AM
wa3ra
Nov 7, 2016 01:53 PM
Dhorsley
Nov 4, 2016 01:15 PM
