Getting thru the firewall
Old Jul 6, 2015 | 09:53 AM
juanjc's Avatar
Default Getting thru the firewall
What's up guys, have any of you guys ever installed some subwoofers in your X-Type?? I just bought my entire audio upgrade, got the new headunit in with no problems, but to wire my subs I can't seem to find a a good/easy way to get the wire from the engine bay into the cabin, I only found one where factory wires are going thru but it's not a rubber graumit it's hard plastic and super tight and sealed can't run my 0 gauge wire thru that, is there any other entree way or am I forced to drill into my firewall??
Old Jul 6, 2015 | 10:12 AM
mjtemple's Avatar
You could try where the hood release cable goes through. On UK cars it's on the right hand side as you look from the front and comes out behind the glove box, I can't say which side it is on for left hand drive models.
Old Jul 6, 2015 | 01:29 PM
wa3ra's Avatar
The hole for the hood release is drilled on both sides, naturally the one
OPPOSITE your steering wheel is unused.
It is plugged, but it is drilled. It is located about a hand's width in and down between the shock tower and the fender/wing.
Old Jun 13, 2017 | 11:40 PM
marciano's Avatar
My right-hand drive car has a large teardrop shaped grommet just to the left of the steering column, very easy to access. You could easily fit several 0 guage cables through it.
To find it, look at the insulation mat just above the top edge of the carpet in the footwell, to the left of the brake pedal. There will be a perforated section which you can remove to access the 3" grommet in the firewall. Drill a hole through both and replace the cutout over the grommet for a better look and noise insulation.
Old Jun 14, 2017 | 08:59 AM
Alfadude's Avatar
You have a right hand drive car and live in the United States? How did you acquire that? That's gotta be a pretty rare car here.
Old Jun 15, 2017 | 12:03 PM
marciano's Avatar
Edit: LEFT-hand drive
Typo.
Old Jun 15, 2017 | 01:42 PM
Alfadude's Avatar
Typo.
Aw, too bad. That would have been kinda cool.
Old Jun 20, 2017 | 04:10 PM
marciano's Avatar
So here are photos of where I found the magical "easy-wire" grommet, large enough to thread several 00 guage wire through.
This is a left-hand drive vehicle.
The rubber firewall liner is perforated for access to the grommet.
I ran the power cable around the shock tower. You should protect the wiring from heat in the engine compartment, I used high-temp split loom.
Old Jun 21, 2017 | 12:10 PM
wa3ra's Avatar
Ahh, the clutch pedal hole...didn't even think about that one! I wonder if there is one of those over on the right side, as well?
Old Dec 27, 2024 | 04:21 PM
Dmich34's Avatar
How would it work if I actually have a clutch pedal there instead.
Poet
Feb 7, 2025 02:18 PM
xjrjag
Oct 24, 2024 03:09 PM
Poet
Oct 6, 2015 09:40 PM
LnrB
Sep 24, 2015 11:16 AM
