Got some codes last night...
Old Apr 2, 2010 | 05:13 PM
pnyklr's Avatar
Default Got some codes last night...
Girlfriend borrowed the car got it washed and put a tank of gas in it
on the way here check engine light came on
I went to autozone and got the following codes
P0174
P0172
P1111
After clearing the codes I got code P1000
Welcome to any ideas to anyone has
Old Apr 2, 2010 | 05:44 PM
Thermo's Avatar
Veteran: Navy
pnyklr, 2 things come to mind.
1) when she got the car washed, did she have them clean under the hood? If so, they may have just sprayed under the hood which has been known to cause misfires due to water getting down around the plugs because of the high pressure water.
2) where did she get gas from? It is possible that the station she went to had a little bit of water in their gas and what you were seeing is the water coming through the fuel system.
I would say to keep an eye on the car and see if it happens again. If it don't, then I would chalk it up to bad luck and continue driving. If it happens again, then further investigating will be needed.
Old May 24, 2010 | 02:47 PM
pnyklr's Avatar
well we are back to the check engine again no idea why
the gas was about 1/4 a tank and the code came on I filled it up with 93
the light is still on its a mystery to me - I have to get the codes read yet again to see what they are
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
Terry H
Jul 4, 2017 05:48 PM
JCam
Oct 23, 2016 08:27 PM
