having major engine issue please help
Old Apr 24, 2016 | 08:55 PM
cronicjohnson's Avatar
Default having major engine issue please help
2004 x type 3.0 v6 I don't understad what is going on
it misses horribly under throttle
If you hold the throttle just right it smooths out and has power
I thought clogged cats I looseNed them up and seperated from the manifold and it did not change anything.
I bypassed my fuel pump power module and gave full power to the fuel pump didn't change anything.
What can I be looking at as an issue I'm not pulling any codes besides wheel sensor
Old Apr 25, 2016 | 09:06 AM
clyons's Avatar
Welcome to the forum.
A little more information would be helpful. How many miles? Has any other work been done? I don't know many that would detach the exhaust manifolds as a first step. Have you checked the spark plug wells for oil, the spark plugs themselves? Missing that bad it is unusual for no codes to be generated. How long has this been going on?
Old Apr 25, 2016 | 09:53 AM
NBCat's Avatar
If there are one or more misfires, the catalysts can be severely damaged. You must locate and correct the source of the misfires, which can be coils that have stopped working or fouled spark plugs.
If the spark plug boss seals are leaking, you probably have shorted coils.
Faycal Moumouni
Apr 23, 2016 06:35 AM
Roger RB
Apr 14, 2016 01:56 AM
JaneB3
30
Apr 13, 2016 01:11 PM
Andi Allko
Apr 4, 2016 04:06 PM
kmarajh
Apr 2, 2016 09:43 PM
