headlight switch removal
Old Apr 4, 2013 | 12:29 PM
bigdiver's Avatar
Default headlight switch removal
Left hand drive 2005 X-Type with auto lights and trip function buttons. Others must be similar.
1 - Remove the main knob. It is held on by a clip at the center shaft. Release the clip by pressing on it through the access hole. The access hole is located at about 6:30 assuming the pointer is 12:00. Some knob positions allow the knob to be pulled towards you and that helps. I used the short end of a 7/64 inch allen wrench.
2 – Remove the cover plate. Pry and prod. Use your head. There will be small bits of broken plastic,but it will all reassemble fine, if you used your head!
3 – Release the spring loaded latch located a bit left of center top. There are two lesser latches on both sides near the bottom. I didn’t do it, but in hindsight, a thin piece of metal might help release those latches.
4 – Boom! It’s in your hands and there is plenty of wire length to allow you to unplug it.
I don’t think the switch can be removed in one piece without damaging the interior. That upper latch is serious. Show me to be wrong!
Old Aug 23, 2014 | 06:08 PM
Dr_killer_UK's Avatar
Default Video of uninstall
Thanks for your info bigdiver
I made a video showing how to uninstall and reinstall for other to see
Old Aug 24, 2014 | 10:00 AM
bigdiver's Avatar
That's a well done video. I never thought of releasing the latch without removing the cover plate. It's pretty obvious, once you see it!
Old Aug 24, 2014 | 11:18 AM
flyrr100's Avatar
I have one in my garage if anyone needs ne.
aholbro1
Dec 29, 2024 06:46 PM
avern1
Sep 8, 2015 06:25 PM
avern1
Sep 6, 2015 04:22 PM
Mosers63
Sep 6, 2015 02:53 PM
laserguy
Sep 3, 2015 02:02 PM
