Hearing car accelerate and decelerate. Strange.
Old May 13, 2009 | 11:05 AM
mohrd's Avatar
bb, from what you are describing, it could be your propshaft center bearing making that whining noise. Do a search on the forum under "propshaft" and see if it makes sense.
Old May 13, 2009 | 12:02 PM
Sevren's Avatar
Exactly what mohrd said.
If the noise is indeed coming from your tranny or transfer case, as your dealer said, then expect to bay big $ to have it replaced.
But it's most likely just the prop shaft issue the way you describe it. It's the center bearing that makes contact with the rubber and the result is a whining noise, especially when it's cold.
The bad news is that to fix this problem you'll need to replace the whole shaft. The good news is that if you don't mind the noise, you can drive your car without worries.
Old May 14, 2009 | 10:05 AM
mohrd's Avatar
As far as the noise goes, your best bet is to visit a Jag dealer. A Jag tech should be VERY familiar with the prop shaft whine and should recognize it right off. It's harder for a non-jaguar tech to diagnose. I had one repair shop convinced it was my transfer case until I did some reasearch, took it to a dealer and had the prop shaft replaced. Whine is gone and although it was still a $1,000 tab, it was better than having someone screw with the TC.
Flush and filling the "sealed for life" components on your X-Type might get a few different views. Do a search here on the forum. Some will say that they did the flush and fill after recognizing there was already a problem happening and the component (TC, Autobox) blew up anyway. Most of us will agree that the "filled for life" for owners like us in the secondary market means the fluids eventually have to breakdown so a flush and fill of the rear diff, TC and tranny is absolutely necessary to keep our X-Types going.
Latest info out there is that Jaguar is easing up on the filled for life on the autoboxes and in fact now has a procedure to swith out fluid via the cooler lines rather than refuse altogether to do it. They still may want $90 a liter for fluid though. That's gotta get better.
Old May 15, 2009 | 06:07 PM
Master Deep's Avatar
Sounds like the drivetrain. My friend had the same sounds. Like a constant whirring. Then his awd system just died and car wouldn't move.
Old May 15, 2009 | 11:02 PM
jvegas's Avatar
Originally Posted by bbarbagallo
Explained the noise at a Jiffy Lube and they refused to do a transmission flush!
Why in gods name would take your car to a Jiffy Lube for anything?
Old May 15, 2009 | 11:45 PM
I'm guilty of this. I've only gone there once and never again. Of course I was standing there supervising them and making sure everything was done right. lol
Old Jan 5, 2012 | 01:04 PM
zoolander's Avatar
I have still not officially bought the car. This forum has me ready to reconsider as it looks like anyone with an X-type has spent close to double the cost of the car just to keep it on the road![/quote]
If you have a chance to walk away...do it
Old Jan 31, 2012 | 09:29 AM
wintercyrk1's Avatar
After looking at the results in the forum, I think I will try and schedule a visit to the Jag dealer here in Sarasota.
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
jdzubas
Oct 4, 2015 09:14 AM
martybmw
Aug 31, 2015 08:41 AM
Sshenton1975
Aug 30, 2015 09:29 AM
