Heat/HVAC issue
Old Oct 2, 2008 | 04:09 AM
peewee's Avatar
Default Heat/HVAC issue
Well, here is my problem. It happened last year too and I just dealt with it but, this winter I would like to enjoy my heat. Well here is my issue:
I can turn the Climate control to 90* but it wont blow hot air unless the car is moving. Last winter, I wouldstart my car up and let it run in order to clear off some of the ice and snow etc. However, when I would get in my car it was blowing cold air. Only whenI starting to drive the car did hot air start to blow. This doesnt matter if its on defrost or on regular heat. Is myClimate control unit dying or is It something to do with the heater core? thanks
Old Oct 2, 2008 | 05:44 AM
JagXV6's Avatar
Default RE: Heat/HVAC issue
What happens when you come to a stop and
are just at idle. Do you loose heat then too?
Old Oct 2, 2008 | 09:20 AM
racerx82's Avatar
Before you go replacing the climate control unit, i would check the temp sensor under the drivers panel. There is a temp sensor with a fan blowing over it. ensure that the fan is operational (key on) and if there are dust bunnies on it, kill them all. If that checks out, It's your climate control.....seen a few on e-bay for 20 bucks, i would jump on it......
Old Oct 2, 2008 | 10:41 AM
racerx82's Avatar
oh, and i forgot, also check all your vacuum lines for any leaks. Do you have any trouble codes?
Old Oct 2, 2008 | 11:37 AM
Brutal's Avatar
Most likely problem is sediment in the heater core that gives insufficitnt coolant flow at low engine rpm until water pump speeds up along woth coolant flow.
Flusg system and disconnect heater core hose and blow compressed air thru which helps to blow all the gunk out . The other common problem for A/C and heat being poor is fresh air blend door motor broken and door sticks open
Way to check this is remove pollen filter and with system running turn on recirc , door should be closed if not its broken and the system will always be fighting cooling or heating outside air
Brutal , thanks for your tips but please keep your caps off
Old Oct 2, 2008 | 12:15 PM
JagXV6's Avatar
I was thinking along the same linethat the cause may be
engine RPM related???
Old Oct 6, 2008 | 06:33 AM
peewee's Avatar
Temp sensor is fine, I cleaned it today. However, it still blows cool air.
When I am in motion the heat will blow fine. When I come to a stop or at idle, almost immediately it starts to blow cool air. I have no trouble codes showing so I dont think its a vaccume line issue.
The coolant appears to be at the proper level.
I guess a trip to the dealer is the next option. I be half of the climate control modules on ebay are POS's if they are selling for 20 bucks.
Old Oct 6, 2008 | 06:36 AM
peewee's Avatar
I should also probably mention that my x-type has 59k miles on it. I bought it a year ago with 35k miles. Would sediment and deposits build up that quickly in the coolant system? I thought you only needed to flush the system every 30k at best.
Old Oct 6, 2008 | 07:15 AM
racerx82's Avatar
Have you had any work done to the cooling sys? AKA, system flush, water pump replaced...etc?? And to be sure, your engine is reaching proper engine temp??
To me it sounds like one of the following: Loose water pump belt (the easiest of these to fix) Stuck thermostat in the closed position, or Possibly air bubbles in the system, or your controller went bad.
Double check your coolant (do not check when hot) ensure it is at the correct mark and if you had to add more then a 3 qts, bleed the system to ensure all air bubbles are gone.
Old Oct 7, 2008 | 02:44 AM
peewee's Avatar
No work was done to the coolant system since I have owned it but, thats not saying much since I have only had it for a little over a year.
Where exactly are the heater hoses? Do you mean the lines heading to the heater core?
I am pretty sure the recir door is fine. Never had a problem with air coming in when it wasnt supposed too.
Old Oct 7, 2008 | 02:49 AM
peewee's Avatar
Also, the coolant level is at the proper height. No need to add any more fluid to the system.
Old Oct 7, 2008 | 07:27 AM
racerx82's Avatar
Ok, check waterpump belt. (rear of engine) if that checks out ok, then it's probably your controller.
Old Oct 14, 2008 | 04:07 AM
peewee's Avatar
pretty sure its not the water pump belt. Dont hear it squealing or anything like that and no leaks from the car. Iam going to try and take it to the dealer next week. Hopefully they dont pork me.
Old Oct 14, 2008 | 05:26 AM
racerx82's Avatar
cool beans, keep us posted
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
joey g
US Northeast
Sep 7, 2015 06:28 PM
carelm
Sep 5, 2015 01:13 AM
