Heater issue 2002 X Type
Old Jan 23, 2009 | 05:04 AM
Real_Tech's Avatar
Default RE: Heater issue 2002 X Type
Check the basics first. Is the coolant full? Does your external temp reading on the climate control panel show an accurate temp? How many miles on the car? Do you know if the thermostat has ever been replaced? Jaguar temp gauges aren't really accurate, they will show a reading in the middle of the gauge for a large range of actual temps therefore your stat could be sticking open and causing the cold heat but the gauge will read normally.
Old Jan 23, 2009 | 06:46 AM
jahuertas's Avatar
I had the same problem; it was due to low antifreeze in the reservoir, went to the jaguar "steelers" and got a gallon of antifreeze ($55). Diluted it with DI H2o, fill the reservoir to max level, and problem was fixed.
Old Jan 23, 2009 | 06:53 AM
The Chris X's Avatar
If we are going to be insulting the dealers, let's at least spell "*******s" correctly. I'm sure Real Tech and Brutal will appreciate it.
The Steelers are from Pittsburgh and will be playing in the Super Bowl, not selling anti-freeze.
Old Jan 23, 2009 | 10:35 AM
jahuertas's Avatar
Hahaa, you're right, I'm sorry. I just can't wait for the superbowl! Besides, I didn't mean it like that, and not to the fine people who work there, but $55 for a gallon of antifreeze?
Old Jan 23, 2009 | 02:00 PM
Real_Tech's Avatar
Trust me, we techs bitch much more about the high price of fluids here than any customers ever could. It makes it hard to sell a trans service when the fluid alone is $500 or more, you have to wait for the car to come in with a leak before anyone wants to spend that kind of money. I will say one thing though. Jaguar has lowered the prices on a lot of their hard parts in the last few years and some things are actually cheaper at the dealer than you can find aftermarket.
Old Jan 23, 2009 | 02:34 PM
ORIGINAL: jahuertas
Glad you are able to take a little ribbing. Maybe I'm overly sensitive because, well, i live in Pittsburgh and Ben R. lives about 2 blocks down the road (talk about a nice pad!!!). Big rally in the 'burgh tonight !!
$55 is crazy, yes.
Old Jan 23, 2009 | 06:28 PM
carlton989's Avatar
1. Go Steelers
2. I had the same problem, the radiator hose was disconnected on mine and I put a new one on...problem solved.
Just my .02
Old Nov 11, 2012 | 05:58 PM
Emiliano Sanchez Pedraza's Avatar
HI, Names Emiliano New to the Forum
Have an X-type that i bout for my sister. having the same problem. BUT worked alll fine till recently.. and suggestion???
Old Nov 11, 2012 | 10:52 PM
Thermo's Avatar
Veteran: Navy
Emiliano, first off, welcome to the forums. I think you will find a lot of useful information here. So, sit back, enjoy a nice cup of coffee and read up. Lots of good information here. Also, if you haven't already, please leave a note in the "New Member" section. There you will learn who the movers and shakers are around here.
As for your issue. First off, check the fluid level in the overflow bottle. Odds are, you will find that it is low. If this is the case, then you have a leak somewhere. Normally the leak comes from the small line that enters at the side of the overflow bottle against the firewall. This is known for cracking (look for a dark white line in the nipple and possibly the hose being loose). Granted, cracks can form anywhere on the bottle. If the bottle is damaged, you will need a new overflow bottle. A new one can be picked up for around $100 and installing it is really easy. From there, you refill the bottle and that is about all that will be needed.
If the bottle is fine and you have adequate level in the overflow bottle, then odds are your water pump is failing. Installing a new water pump is easy. If you have any mechanical ability, you can do the water pump in this car. If you need help, let me know.
If you are not able to find your leak, let us know and we will help you out.
Old Nov 12, 2012 | 09:16 PM
Chris "Thermo" Coleman and K'Re Ann,
Thank you man, that really did help a lot! I also found the passenger vent flap was sticking and got that fixed as well! Really appreciated
Old Jan 19, 2014 | 12:55 PM
marquisdesade's Avatar
Default Loss of heat
Hi everyone. Fairly new jaguar owner (18 months). Always wanted one.
I had heater problems and found coolant was low. Rectified this this with top up and antifreeze. This correctyed it for a few days but now haas returned to cold air. I will check all the avenues previously described. However, until corrected, if I continue to drive even with correct coolant levels, can this cause damage to the engine. My thoughts are no.
Am I the only only UK correspondent?
Old Jan 19, 2014 | 01:24 PM
Originally Posted by marquisdesade
......... Am I the only only UK correspondent?
Welcome to the forum marquisdesade,
No - you are not alone!
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
h4wk
Nov 27, 2015 05:10 PM
montypeek
Sep 6, 2015 04:57 PM
Rusty1952
Sep 1, 2015 05:45 AM
roumor
Aug 28, 2015 01:02 PM
brent65622
Aug 26, 2015 08:41 AM
