(Help)04 Xtype 3.0 gas issue
Old Apr 20, 2014 | 06:00 PM
magicjuan17's Avatar
Default (Help)04 Xtype 3.0 gas issue
Getting extremely expensive hope somebody has some information or advice for me I've noticed lately I've been losing a lot of gas in my car I've been refilling a lot often than usual is there any particular thing that I can do to check if there's any issues or is there any advice that you may come across in owning your Xtype only if I do not have a check engine light car seems to run pretty well have not had any issues so I'm not quite sure where to start- i'm in America so I use gas you usually I use us Sunoco ultra which is 9.3 -for those that have been owning your next type for quite while I would love some advice or some particular details that I can use so I can save some money in the long run I understand the vehicle is very heavy to be a sedan I did check the brakes if there were locking on me by putting it in neutral and rolling it seems fine I did a tune up on my own about a year ago I changes spark plug gaskets air filter water pump coolant reservoir breather air pipe- massive flow sensor and also coolant temperature sensor- any suggestions would be great thank you
Old Apr 20, 2014 | 07:05 PM
Alfadude's Avatar
Tell us what kind of MPG you are getting. What MPG were you getting before to make you think you are having an issue? Anything change recently in your driving style? Have you recently replaced anything on the car or have had any other issues with it? The more info you can provide the more likely it would be that someone could help diagnose your issue.
Just a suggestion: It's much easier to read and understand your post if you would use some puntuation
Jjscruggs1
Aug 2, 2017 04:40 PM
XJsc-guy
Nov 23, 2015 01:56 PM
alpecsa
Sep 7, 2015 11:55 AM
Wes Steenrod
Sep 6, 2015 06:52 PM
Bowman
Sep 3, 2015 03:17 PM
