Help! Added wrong oil to transfer case
Old Dec 13, 2011 | 04:50 PM
yeeran's Avatar
Default Help! Added wrong oil to transfer case
Hi all,
I just found that I added 75w-90 instead 75w-140 to transfer case. Is it a big problem? Thanks very much.
Ran
Old Dec 13, 2011 | 06:07 PM
brucelee's Avatar
Yup. I would change it ASAP.
Old Dec 13, 2011 | 07:22 PM
Thermo's Avatar
Veteran: Navy
yeeran, are you going to trash your transfer case if you drive it, I don't think so. can you do long term damage, very possible. Granted, I used 75W-90 in the rear end of my Ford truck when it called for 75W-140 (both were full synthetic) and I didn't see any additional wear on the gears over time. So, what it can do to the transfer case is hard to say.
At highway temps, the lube is going to perform pretty much the same since both lubes have the same thickness at temp. It is when the transfer case is cold that you are going to "see" the different lubricating properties.
Old Dec 13, 2011 | 07:39 PM
yeeran's Avatar
Thanks for your inputs.
I will change it right now after driving about 15 miles.
Thermo,
I guess 75w-90 and 75w-140 have the same properties at low temperature, right? Since both of them have 75W. Sorry if I am wrong. I am new to car.
Old Dec 14, 2011 | 11:20 AM
Thermo's Avatar
Veteran: Navy
yeeran, just the opposite. At operating temperatures, they will have the same characteristics since the first number is the thickness of the oil when it is hot. The second number is the thickness of the oil when it is cold. The 90W oil is going to be thinner than the 140W oil.
Old Dec 14, 2011 | 03:16 PM
rothe's Avatar
Also, make sure you use a GL-5 specific gear oil in your transfer case (and differential, too). GL-4 is for manual transmissions. The difference between the two specs is that GL-5 is for gears that are subject to higher pressures than would be found in a manual transmission. See the conclusion section, here: AMSOIL Article - Gear Oil Basics
And you do not need a gear oil that includes sulfurous limited-slip friction-modifier differential additives. I can't find a reference at the moment, but I distinctly recall reading (perhaps on Redline Oil's web site) that such additives can do damage to bronze and brass parts such as those commonly found in manual transmission synchronizer bearings. Those additives aren't necessary for our cars, since they don't use a clutch-type limited-slip differential. So I'd just as soon avoid using a product that contains the additives. If you're not sure, just get a whiff of the oil that you're using - if it stinks like something died in the bottle three years ago, it probably contains the additives!
Old Dec 14, 2011 | 03:58 PM
Thermo's Avatar
Veteran: Navy
rothe, the sulfurous additives are meant more for the rear differentials of trucks that have limited slip units installed in them. Like you mention, those fluids are not necessary in our applications as we don't have anything that operates on those principles. That way you are garanteed to have more oil where you need the oil, not some additive.
Old Dec 15, 2011 | 09:23 AM
Are you sure Chris?
It was always my understanding that the first number was the cold viscosity and the second the hot.
Old Dec 15, 2011 | 09:40 AM
Thermo's Avatar
Veteran: Navy
Norri, you are correct. I got the numbers mixed up in my head. Granted, I need to go back and do some more looking into this as I would think when you heat up the oil/lube, it would get thinner and therefore flow through the orifice for testing faster, leading to a lower viscosity. But, in the quick reading, it may be a relationship thing, not a physical property thing (hence where my confusion came in).
Old Dec 15, 2011 | 01:34 PM
yeeran's Avatar
Thanks to all.
I used Royal Purple gear oil which is recommended in many posts here.
Old Dec 15, 2011 | 01:59 PM
yeeran's Avatar
Autovip - how to tilt a car .... - YouTube
Do not need to swap tube and plug if we have this...
Old Dec 15, 2011 | 02:03 PM
Mikey's Avatar
Originally Posted by Norri
Are you sure Chris?
That's correct.
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
Scarecrow
Mar 28, 2016 03:17 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Dymaxxion
Sep 4, 2015 02:40 PM
