Help auto gearbox intermittent problem
Old Jun 9, 2017 | 01:54 PM
Jagisbest's Avatar
Default Help auto gearbox intermittent problem
I have a 2010 auto x type occasionally if i drive it hard particuarly from a standstill my gearbox failure message pops up and it goes into limp home mode. Turning the ignition off clears the fault and no problems seems to exist with the kickdown as it usually is very smooth i was thinking i either need to top up the transmission fluid or its a sensor failure can anyone make any suggestions ?
Old Jun 9, 2017 | 04:35 PM
JagV8's Avatar
Add car details.
Old Jun 10, 2017 | 05:14 AM
Jagisbest's Avatar
Originally Posted by JagV8
Add car details.
its a 2.2 dpf auto gearbox 2010 facelift model x type
Old Jun 10, 2017 | 10:08 AM
avern1's Avatar
I would start with finding a mechanic that can read the C codes and find out if any codes are stored. The standard code reader can't read the transmission codes. I would also recommend a good transmission service, oil and filter change.
Once you can get the codes read let us know what they are and we can go further from there.
Old Jun 10, 2017 | 11:36 AM
Jagisbest's Avatar
Thanks will do
Old Jun 10, 2017 | 02:41 PM
Dell Gailey's Avatar
2010?
Jaguar X-Type is an entry-level luxury car that was manufactured and marketed by Jaguar Cars from 2001 to 2009 in a single generation under the internal designation X400.
Old Jun 10, 2017 | 02:59 PM
Jagisbest's Avatar
Originally Posted by Dell Gailey
2010?
the car is on a 59 plate but was registered jan 2010
Old Jun 11, 2017 | 09:02 AM
JagV8's Avatar
It sat somewhere for a while.
Old Jun 12, 2017 | 12:43 PM
Jagisbest's Avatar
got the codes read and it is a turbo actuator ?? According to the diagnostic reading up though there are vanes that will need to be unblocked or replaced. Is this a diy job or does a skilled mechanic need to do this? I have changed alternators brake pads and random hoses in the past so i have limited technical skill not a complete novice
Old Jun 12, 2017 | 02:39 PM
avern1's Avatar
Your best bet is to post the code numbers. A lot of times the interpretation is in error. If you post the numbers we can try to help sort it out.
Old Jun 12, 2017 | 03:17 PM
Jagisbest's Avatar
The code is p132A
Old Jun 18, 2017 | 11:09 AM
Thang Nguyen's Avatar
The car is build for pleasure pony ride, you can drive hard on the speed. It sound like you want to drag race at the traffic light, it not build to flex the muscle, just ignore the guy next lane; You drive hard from stand still it'll short life to the TM & TC.
Old Jun 18, 2017 | 03:36 PM
JagV8's Avatar
Ignore above. Seems a turbo fault and any engine fault may upset the gearbox so address the fault.
Old Jun 19, 2017 | 01:27 PM
https://www.jaguarforums.com/forum/x...-codes-133428/
Old Jun 19, 2017 | 02:01 PM
Jagisbest's Avatar
Superb thanks if it works on mine it will have saved me a few hundred pounds 🤗🤗😁
Old Jun 19, 2017 | 07:13 PM
Old Jun 22, 2017 | 01:35 PM
Jagisbest's Avatar
having made a few exploratory surgeries the turbo vanes seemed to be sticking i have gave them a good clean and used the innotec turbo cleaner and i am now waiting to see if this cures the problem
Old Jun 23, 2017 | 01:57 AM
Dandy
