help! greasy/oily part
Old Jun 1, 2016 | 12:06 AM
nicobenny's Avatar
Default help! greasy/oily part
Hello everyone,
I took a look at my engine as I wanted to have a visual inspection before servicing it, which I plan on doing next week.
I noticed that a part was kind of oily/greasy.
I don't exactly know what that part actually is and whether I should be overly worried about it being oily/greasy.
On the picture I've joined, it's the part highlighted in green.
Any help/advice appreciated!
Many thanks!
Attached Thumbnails help! greasy/oily part-engine.jpg
Old Jun 1, 2016 | 12:08 AM
nicobenny's Avatar
I forgot to mention: it's a 2006 2.2d X Type Estate model.
Old Jun 1, 2016 | 08:02 AM
DPK's Avatar
DPK
Looks like the starter motor...It shouldn't be oily..Maybe leaking down from above somewhere on to it.
Old Jun 1, 2016 | 11:12 AM
nicobenny's Avatar
Might be coming from the power steering pump that's just above it.
I noticed my power steering fluid was a bit low (just on the lower mark of the measuring shaft in the power steering fluid cap).
The leak is not severe.
If so, do you know if those "power steering stop leak" additives are recommended on an X Type and if they actually work ??
Old Jun 1, 2016 | 11:24 AM
DPK's Avatar
DPK
Personally, I wouldn't use any kind of stop leak in the P/S pump..I would try to fix the leak or replace the pump....messing with the steering is a big concern of mine.
Jacsun
May 3, 2018 01:33 AM
aquifer
Jun 3, 2016 09:08 PM
Safari
May 26, 2016 10:33 PM
AnD3rew
May 19, 2016 11:35 PM
