High pressure on low port AC with good charge air conditioning
Old Jun 23, 2025 | 10:16 PM
Ronks2's Avatar
Default High pressure on low port AC with good charge air conditioning
Any known issues, quick fixes or things to check?
I went through the forum and haven't found a repair yet.
Back in January it was in the 40's and the AC seemed to work fine.
The car was parked in the North East outside until April, and the AC wouldn't work when I came back.
Fast forward to June and no cold air above 70 degrees. In the rain and 60 degrees the ac blew cool.
The clutch is engaging the compressor. With the cheap charge can, the low side pegged the gauge. Even with the compressor running, it wouldn't draw freon from the can.
This morning I threw a real set of gauges on and both sides read about 100, at start up.
The system will hold a vacuum.
Any ideas would be appreciated.
Old Jun 24, 2025 | 01:00 AM
Dell Gailey's Avatar
https://www.jaguarforums.com/forum/x...essure-100081/
Old Jun 24, 2025 | 08:05 AM
motorcarman's Avatar
No idea what car you have but Jaguar issued a TSB years ago.
File Type: pdf
Old Jun 30, 2025 | 08:19 PM
95naSTA's Avatar
What do the gauges read when the compressor kicks on? If it stays 100/100 the compressor isn't working. This might be obvious but it also sounds over charged.
Old Jul 13, 2025 | 10:13 PM
Ronks2's Avatar
Thanks for all the feedback. I had the ac evacuated and level was fine, so we went ahead and replaced the compressor with one off Amazon. Recharged at 1.12 lbs and works liked a brand new car.
Went about 100 miles and then the car threw a few codes and ABS and traction control warnings and dumped me into third gear limp mode.
Here is the odd thing when i looked at the compressor, there are four wires coming off of the alternator, two of which go directly to the ac compressor. Anyone have any prior knowledge of a compressor issue causing limp mode?
Cibermac
Jun 23, 2022 09:11 PM
annamiata
Apr 14, 2019 01:54 PM
Vee
Sep 13, 2015 12:19 PM
rea98d
24
Jun 18, 2014 08:17 AM
e1rfw01
May 10, 2014 09:03 AM
