How big is the fuel tank?
Old Aug 4, 2013 | 07:17 AM
shotime92's Avatar
Default How big is the fuel tank?
How many us gallons does my 03 x type hold? Did a search and couldn't find anything. Thanks.
Old Aug 4, 2013 | 07:21 AM
Thermo's Avatar
Veteran: Navy
Shotime92, the tank by definition is only 14 gallons. But, I think that they understate the tank some as I have been able to fit 14.5 gallons into the tank a few times with about a gallon left based on the "miles to empty". But, I wouldn't rely just on the dash telling you that you are good for so many more miles. I have never pushed my car to the point of running out of fuel. So, exactly how much it would take to top off the tank is hard to say. So, in reality, it is probably a 16 gallon tank.
Old Aug 4, 2013 | 10:37 AM
MRomanik's Avatar
Veteran: Air Force
The most I ever got in my 07 was about 15.3 US gallons. The manual says 16.2 US gallons total fuel capacity including a reserve (unindicated) of 1.3 US gallons.
Old Aug 4, 2013 | 12:41 PM
shotime92's Avatar
Thanks for the response. At 89k miles now and the mpgs aren't the best I think. Guess its time for a tune up.
Old Aug 4, 2013 | 06:31 PM
Thermo's Avatar
Veteran: Navy
showtime, before you get crazy with the tune up, give the rear brakes a once over. In my playing with my car, I have noticed that the rear calipers can stick a little bit and that by using the e-brake a lot, will cause the rear pads to drag even with the e-brake released, resulting in lower fuel mileage. If you want me to go into more detail, let me know. Granted, at 89K miles, you are coming close on needing new plugs and PCV valve, so, that would not hurt either.
Old Aug 4, 2013 | 07:18 PM
DPK's Avatar
DPK
I usually look in the Owner's Manual for this kind of info, or Google it..
Maintenance 7-13
Capacities
US Quarts Litres
Engine oil change including new oil filter. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.1 5.8
The rear axle (final drive unit), transfer box and automatic and manual transmission units
(gearboxes) will not normally require to be checked or topped up.
Cooling system, including reservoir and climate control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.5 8.0
Windscreen washer reservoir:
– without headlamp powerwash . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
– with headlamp powerwash . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
2.6
6.3
2.5
6.0
US Gallons
Fuel Tank
Total fuel tank capacity . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16.2 Gallons
Indicated refIll capacity – E to F on fuel gauge . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14.9 Gallons
Unindicated (reserve) capacity . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.3 Gallons
dsnyder586
Dec 29, 2024 07:39 PM
Razor
Aug 28, 2019 08:34 PM
ccfulton
Sep 20, 2015 05:15 PM
hen555
Sep 7, 2015 11:13 PM
deanh
Sep 6, 2015 08:20 PM
