how can i tell if my TC seal is damaged?
Old Jul 29, 2008 | 12:46 PM
matl's Avatar
Default how can i tell if my TC seal is damaged?
Hi i replaced my oilpan (dont recomment anyone attempt this unless theyre experienced mechanics) anyway come to find that i removed the halfshaft and might have damaged the internal seal. What will happen if its damaged? will there be overflow? overheat? i want to keep an eye on it to see if its damaged. thanks
Old Jul 31, 2008 | 11:15 PM
matl's Avatar
Default RE: how can i tell if my TC seal is damaged?
ANYONE???
Old Aug 1, 2008 | 01:50 AM
jvegas's Avatar
ya got me.....
Old Aug 1, 2008 | 06:54 AM
Thermo's Avatar
Veteran: Navy
If you have an issue, you will most likely see leakage at the halfshaft. So, if you aren't dropping fluid. All should be good. Chris "Thermo" Coleman
Old Aug 1, 2008 | 06:55 AM
Thermo's Avatar
Veteran: Navy
I will double check the drawings to make sure that there isn't something more to this issue. Shouldn't be. Chris "Thermo" Coleman
Old Aug 4, 2008 | 01:12 PM
matl's Avatar
Ok cool, i've been keeping an eye on it and so far so good. My other worry is that its not visible and meanwhile the TC is slowly getting damaged...
Old Aug 4, 2008 | 02:12 PM
Dennis's Avatar
ud
If it ain't leaking and you have it full of lube..you should be okay..
Old Aug 5, 2008 | 05:49 PM
jag_genius's Avatar
basically transmission fluid gets mixed with your TC fluid and visa versa.. thereare no external leaks.. sometimes. you can take the shaft out and be ok.. sometimes.. they damage.. about a 50/50 shot..
Old Sep 11, 2008 | 12:30 AM
Alaska Jag's Avatar
Jag-Genius.....
how do the fluids get back and forth? There is a double internal seal around the drive shaft, and an O-ring that is on the outside of the T-case that slides into the tranny. The T-case is sealed off from the tranny.
If the tranny fluid mixed w/ the T-case, then my T-case would not be sitting on my work bench split in half right now!
Ak Jag
jorgef858
Jan 14, 2016 11:32 AM
prettydaim
Nov 12, 2015 08:05 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
