How do i fix a loose seat?
Old Dec 13, 2008 | 07:10 PM
Jaggyx's Avatar
Default How do i fix a loose seat?
Hi i have an 02 jaguar x type 3.0 and the drivers side seat seams to be loose.
I check the bolts the seat attached to and the bolts for the rails of the seats and they seem to be tight .
Do anyone else no where to tighten?
Thanks,
Jim
Old Dec 13, 2008 | 07:32 PM
jvegas's Avatar
Default RE: How do i fix a loose seat?
damn, i forgot about this issue with the 02-03's for that other post... there is a TSB for this. I think you need to get the bracket replaced.
Old Dec 13, 2008 | 08:24 PM
Luemasta32's Avatar
I got the same problem with BOTH of my front seats! How much do new brackets run? It's not that major of a thing to me, but if it's relatively cheap I would definitely look into it.
Old Dec 13, 2008 | 08:34 PM
Jaggyx's Avatar
yeah its not a major thing to me either i just dont want it to get looser over time and fall off
Old Dec 13, 2008 | 08:44 PM
queenmb's Avatar
In the event of an accident, that cannot possibly be safe.
Old Dec 13, 2008 | 09:17 PM
Jaggyx's Avatar
wow so then i guess its a must to replace it.
Does anyone know how much a new seat bracket will cost?
Old Dec 13, 2008 | 09:45 PM
MarkC's Avatar
A fix for the seat rocking problem in 2002 X-types is addressed TSB XT501-03 amended 01/04. This fix is apparently only applicable to X-types from S/N C00001 to C75251.
The TSB describes a spring that is inserted between two pipes in the seat frame as well as a set of wedges that are installed under the frame rails. The wedges are only installed if the spring does not cure all of the rocking.
The fix looks rather simple, but like everything Jaguar, the parts are stupid-expensive....something like $100 per seat. One of the Jag techs on this forum quoted me the same price.
I have a copy of this TSB as a .pdf file. If you need it, let me know.
This should also show up if you do a search.
Mark
Old Dec 13, 2008 | 10:15 PM
Jaggyx's Avatar
Hi mark could you please send me the pdf file so i can take a look at it.
Old Dec 14, 2008 | 08:00 PM
MarkC's Avatar
Jim, check your E-mail
Old Dec 14, 2008 | 11:30 PM
Luemasta32's Avatar
Hey Mark would you mind hitting me off with this PDF? In the mean time I guess I'll just be claiming ejection seats in the front of my X. Now how's that for custom?javascript:void(opener.AddText('[sm\=lol.gif]'));%20self.focus();
Old Dec 14, 2008 | 11:31 PM
Luemasta32's Avatar
hahahah I'm not a moron when I comes to computers, but why the hell are all of my smilies just coming out as the link?
Old Dec 17, 2008 | 11:02 AM
mr.xtype's Avatar
My driver seat started squeeking latley... does anyone knwo how to cure this? I didnt check if there was any play in the seat... its just when I drive if my body moves around i hear the seat squeek. It all started after certain activities took place in the front seat with a certain gymnast of a girlfriend...
Old Dec 17, 2008 | 01:39 PM
The Chris X's Avatar
Mr. X type - are you sure it is not the center armrest squeaking? It is a more likely culprit, and not to in any way underestimate the "flexiness" of your girlfriend, it would be quite possible the armrest would have been stressed during just such an activity.
Old Dec 24, 2008 | 08:01 AM
mr.xtype's Avatar
Yes I am sure its not the arm rest. Though the arm rest feels very cheaply made it is the seat. I think maybe a weld inside the frame or something may have broken.
aholbro1
Dec 29, 2024 06:46 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Super Cat
Sep 9, 2015 03:24 PM
JagLove86
Sep 6, 2015 10:36 PM
AL NZ
Sep 4, 2015 08:39 PM
