How to remove the ac drier?
Old May 2, 2013 | 03:02 PM
DPK's Avatar
DPK
Just the Dryer?
Old Jul 3, 2013 | 11:32 AM
Xx_Four_Stroke_xX's Avatar
Default Having Trouble
I'm looking for some suggestions or advice on how to remove the ac receiver/drier spring connection closest to the firewall. I have everything else loose and it's just dangling there waiting to be disconnected. I have the proper 3/4 inch spring coupling tool, I can here it snap into place but it doesn't matter how hard I pull, it won't budge. Any thoughts???
Also what is the best way to reattach the receiver/drier's front most 8mm bolt (the one above the washer reservoir)? It was way to hard to get it off, and unless I come up with an easier way to install it, i'm not going to.
Thanks.
Old Jul 3, 2013 | 02:21 PM
Update
I managed to get the receiver/drier off by cutting the rubber tubing between the spring coupling and the drier and wiggling the connection, it came right off. Also use some PB Blaster.
I still would like some advice on how to re-install the 8mm bolt on the drier above the washer fluid reservoir.
Old Jul 4, 2013 | 12:12 PM
AlfaVeloce's Avatar
Wow that must have really been on there.
I remember one of the bolts was hard to get but I don't remember off hand how I did it. It may be the one I used a socket on a very long extension. Or, it could have been one of those ratcheting box end wrenches with swiveling box end. I used both on several bolts up in there. Push come to shove, take out the reservoir.
I wouldn't recommend going without it. Lots of vibration in there.
Old Jul 4, 2013 | 03:32 PM
Yeah it was really on there and a ratcheting box wrench would have been nice since a socket wouldn't fit. To reinstall it, I ended up loosening the passenger side of the bumper enough to drop the reservoir a few inches. But it is all back together now awaiting a flush and refill sometime next week.
Old May 19, 2019 | 10:13 PM
forcemajeure's Avatar
Originally Posted by Xx_Four_Stroke_xX
Update
1. So you mentioned how hard it was to remove the AC coupling. I spent most of today trying to put the new hose back into the coupling. While sliding/hammering in, the o-rings we're getting shredded and when I vacuumed the system it won't hold a vacuum. I can't get it to click back in it is almost there all three orings are inserted. I mean I was using a sledgehammer and PB blaster how did you get it to work?
2. Use a self-tapping screw and mount that f****** thing wherever you need to. Improve the system.
3.Side note in order to release the tension from the serpentine belt tensioner I cut into the frame near the passenger headlight to fit in a standard 3/8 serpentine belt tool. I'm just sick and tired of no maintenance in mind manufacturing. NOTHING is easy on an Xtype!
4. I found on YouTube just search AC coupling removal a video of a guy showing a tool he made out of a pipe clamp. You basically cut off the diameter of the pipe and it's an amazing little tool.
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
mrsimpson
Sep 15, 2015 01:10 PM
SeanU
Sep 14, 2015 04:31 PM
doctordeuce
Sep 12, 2015 08:30 AM
