how to remove the rear window panel? instruction on jtis?
Old Jun 22, 2009 | 10:00 AM
patrick12's Avatar
Default how to remove the rear window panel? instruction on jtis?
Hello,
i want remove this Panel/Blind inside the car?
Can not find a Instruction in JTIS for the 2002 X-type....or is there a intsruction?
Patrick
Attached Thumbnails how to remove the rear window panel? instruction on jtis?-p1010799.jpg
Old Jun 22, 2009 | 11:25 AM
The Chris X's Avatar
I'm confused as to what panel you mean. The door panel?
Old Jun 22, 2009 | 11:46 AM
patrick12's Avatar
i marked it red
Old Jun 22, 2009 | 01:54 PM
christo's Avatar
I think the rear seats have to come out...
Old Jun 22, 2009 | 03:58 PM
patrick12's Avatar
there must be a instruction on jtis, but i can not found where....
Old Jun 23, 2009 | 06:00 PM
l17led's Avatar
Pull the lower of the back seats up ( good pull up from the front). Then two large tox bolts hold the rear seat on(Large bracket, easy to see). When removing the backrest lift up and towards yourself. Once the backseats are out you need to remove the rear side plastics (Clips and screws if I remember correctly). Then undo any screws holding down the piece you want to remove (Remember to remove the vents and other plastics tht are in that rear panel). Jobs a good'n! (I had to do this when adding rear sensors to my dads car and that is where the beeper is hidden.)
Old Jun 24, 2009 | 06:44 AM
Originally Posted by patrick12
i marked it red
My bad, the thumbnail wouldn't load to a bigger pic yesterday (for whatever reason).
l17led got it right. If you don't have any soft-pry tools, now is the time to pick them up.
99xk8guy
Sep 29, 2025 10:51 PM
cissdm
May 3, 2016 06:02 AM
jdzubas
Oct 4, 2015 09:14 AM
davidladewig
Sep 3, 2015 06:32 PM
Joey T
Sep 3, 2015 05:31 PM
