"I didn't know my Jag did that!" thread
Old Aug 26, 2011 | 02:34 PM
  #61
AigleGris's Avatar
Found a new feature yesterday. When I pressed the lock button on the key fob the horn sounded twice and lights flashed. Turned out I had not fully closed the trunk/boot.
Old Aug 26, 2011 | 02:59 PM
  #62
Cambo's Avatar
Originally Posted by dd823
OK so I checked mine and the windows go down when you hold the unlock but they don't go up
You have an X-Type?
Old Aug 26, 2011 | 08:38 PM
  #63
jprentice's Avatar
The 420G did have that
Old Aug 27, 2011 | 09:51 PM
  #64
Patterson's Avatar
I didn't know until the a few days ago that my X has rain sensing wipers! This is the first car I've owned with them. As I was driving the rain started to really pound and I noticed the wipers start going faster! I was like wtf? Then later the rain subsided and they slowed down, I was like double wtf? I guess I hadn't noticed that the wiper control has an "Auto" setting. Definitely a pleasant surprise!
From J.D. Power.com
How do they work?
The technology behind rain-sensing wipers is not complicated. A small area of the front windshield glass (usually located on the outside of the vehicle, opposite the rear-view mirror) is monitored by an optical sensor. The sensor is designed to project harmless infrared light at the windshield at an angle and then read the amount of light that is reflected back. A clean windshield will reflect nearly all of the light back, while a wet or dirty windshield will cause the light to scatter. The optical sensor can determine the necessary frequency and speed of the windshield wipers by monitoring the amount of light reflected back into the sensor.
Old Aug 29, 2011 | 08:18 AM
  #65
pab's Avatar
pab
Be careful with the auto-wipers...
I have scratches in my windshield that are obviously from the wipers starting up when the windshield was dry and dragging road-grit across the glass.
For the first three years I've owned my X-Type I just left the wipers in auto. I regularly saw them sweep when there was not water on the windshield. It would regularly happen at dusk when the sensor obviously was confused by the lack of day light.
Recommend that people not leave them on auto
Jaguar: Grace, Pace, and Space - Sir William Lyons
Old Aug 29, 2011 | 05:09 PM
  #66
QuintonChester's Avatar
Not sure if anyone has noticed this, it's not really something it does, but it's cool, and I found it unique. On the fuel gauge, there is an arrow indicating which side your fuel door is on
Old Aug 30, 2011 | 02:00 AM
  #67
Patterson's Avatar
I agree. The "Auto" setting for the wipers is only for when it is actually raining or even drizzling. They are designed to keep up with the ebb and flow during a rainy trip. I only click the control arm up to activate the wipers if it is actually raining. If not, I leave the lever arm in the off position. Wiper motor off..
Old Aug 30, 2011 | 11:14 AM
  #68
KaysKat's Avatar
I didn't know my Jag enjoyed tires like they're cat-nip!
Old Sep 1, 2011 | 08:36 PM
  #69
harryc's Avatar
Here's a feature I bet many of you don't know. Try putting your transmission in gear with the car completely off. It gets mad at you.
Old Sep 1, 2011 | 10:39 PM
  #70
04xtypeguy's Avatar
It will do that if one of your doors isn't closed as well.
Old Sep 2, 2011 | 09:31 AM
  #71
91stealthes's Avatar
>If you hold the lock button on the keyfob with your windows down, it will lock the car and roll the windows up 8)
Nope no do that on my '05, as someone else said earlier that must have been something they discontinued by '05... :-(
Nope, it IS available on '05. I had to have it programmed by the dealer. I had it done about 2 months after I purchased the car in April of '05.
Regarding global open and close. When I got it done, I was informed that it can do either global open, or global close. You can choose.
I choose global close, as it is more important to me. Shut the car off, get out, walk away, hold the lock button for 3 seconds, everything closes and locks...fantastic!
Old Sep 3, 2011 | 07:10 PM
  #72
04xtypeguy's Avatar
Do you rotate them every 3000 miles? That helps extend the life of the tire (at least in my experience)
Old Jan 25, 2012 | 10:30 AM
  #73
Guillermo Perez's Avatar
Default TEST mode codes...
Here is a link where explains the meaning of the TEST codes.
Jaguar X Type Instrument Cluster Diagnostic codes
Old Jan 25, 2012 | 05:50 PM
  #74
jonesy1974xtype's Avatar
You may find this post i created useful. its a summary of the uk jag forum on the same topic which was 40 pages long. I summarised what I thoghyt was the most useful bits for the x type.
https://www.jaguarforums.com/forum/x...92/#post454155
Old Jul 15, 2017 | 02:07 PM
  #75
Edward Stuart Hill's Avatar
I think this was only on the 03 or 04+ models though, not completely sure. Or if you just turn the key while it's in the door to make it lock, and hold it for 2 seconds it will roll them up.
All x-type jags do this as long as you have 4 electric windows, if it does not work turn on ignition, press window down for 5-6 seconds then wind up for 5-6 seconds this resets the window, do this for all 4 windows then wind all 4 down and get out the car lock it with the key and press it and hold the lock... It should now wind up all the windows at once
Old Jul 15, 2017 | 02:55 PM
  #76
Dell Gailey's Avatar
Thumbs down
My research on "global" window up is = European cars do indeed have this feature. U. S. Cars DO NOT and a Jag tech said the reason it is not SUPPOSED to be enabled here in the U.S. is that when the global window up is used it by passes the anti-trap relay on the windows. I have tried it on mine and it is indeed disabled.
Old Jul 16, 2017 | 03:27 AM
  #77
DUNKS's Avatar
One amazing thing even my Sovereign does not have is bulb failure indication. A friendly policeman pointed it out to me! Amazing because even low spec Brit cars have this feature.
Also if you lose power to the trunk/boot latch when it's closed. YOU ARE IN ALL SORTS OF TROUBLE. Especially Brit spec as we don't have the internal strap to open same from inside. "we don't tend to lock our kids in there"
Old Jul 16, 2017 | 05:45 PM
  #78
So I found a post of "reportedly" how to enable global up for European cars. I tried it for mine and still a no go, although manually using the key by locking, releasing and then holding to lock position again, will now raise windows left open.
Similar to resetting the auto up function. The window buttons have 5 positions = 2+, auto up, 1+, up, 0, neutral, 1-, down, 2+, auto down. Instructions were hold up button in position 1+, to fully close window, wait 2 seconds, release button for 2 seconds, again lift button to 1+ position for 4-5 seconds (but not longer than 6 which automatically cuts out power to preserve motor).
This is SUPPOSED to enable global close on key fob by locking, releasing and then holding lock fob longer than 3 seconds.
  #79
Sorry 2- for auto down
Old Jul 17, 2017 | 08:33 AM
  #80
dennis black's Avatar
are you doing that with the keys in the lock or standing away from the car
