I found a small hole in the exhaust system
Old Jan 22, 2019 | 12:48 PM
Luke Farrell's Avatar
Default I found a small hole in the exhaust system
What effects will this have on my cars performance? Will it cause back pressure and give a rougher idle? I'm sure it will fail the NCT over this.
should I nip this in the bud now or can I leave it another month or 2
Old Jan 22, 2019 | 01:20 PM
Dell Gailey's Avatar
Could make an O2 sensor go off.
Old Jan 22, 2019 | 01:47 PM
Steve M's Avatar
Whereabouts in the exhaust system,?
Manifold, pipes, cats, silencers?
Can you just slap some exhaust tape over it?
Old Jan 22, 2019 | 02:32 PM
Brutal's Avatar
Are you talking about the drain holes to allow condensation to drain out and not fill the exhaust with water? If so theyre there for that reason
Old Jan 23, 2019 | 03:57 AM
Default Here's a picture
The area around the hole is very fragile from the rust
Old Jan 23, 2019 | 04:19 AM
Steve M's Avatar
Again, where is the hole?
Old Jan 23, 2019 | 05:19 AM
Default Pic won't upload
I can't seem to upload a picture but the hole is in the catalyst exhaust pipe on the far side just in the grove where the catalyst connects to the rest of the exhaust
Old Jan 23, 2019 | 07:27 AM
Steve M's Avatar
Can you get in there with some exhaust tape or Gun Gum or similar?
https://www.halfords.com/workshop-to...gum-putty-200g
Old Jan 24, 2019 | 06:46 PM
That gun gum looks perfect for the job thanks
Old Jan 24, 2019 | 06:48 PM
Old Jan 24, 2019 | 06:49 PM
Old Jan 25, 2019 | 10:14 AM
Brutal's Avatar
Any good muffler shop or wleder can weld that up
Old Jan 29, 2019 | 11:10 AM
Default Gun gum
I filed off most of the rust around the hole and have it a little sanding before I packed on a load of gun gum.
I put on a lot to make sure I prevent another hole appearing anytime soon. I will replace this part in a year unless it gets worse in the meantime.
this is just my quick fix to pass the NCT in a couple of months.
Old Jan 29, 2019 | 11:13 AM
Default File and sand
This is it filed and sanded, the rust isnt gone 100% but this is just a quick fix to get through another year. The area around the hole is solid i had recoved any loose metal.
Old Jan 29, 2019 | 11:15 AM
Old Jan 29, 2019 | 11:17 AM
Default Gun gum
Plenty of gun gum
Old Jan 29, 2019 | 11:19 AM
Default Gun gum
Old Jan 29, 2019 | 02:03 PM
Steve M's Avatar
Hope it works ok!
xjrwithproblems
Aug 10, 2019 07:30 AM
astark
Aug 31, 2018 09:00 PM
chtp66
May 26, 2014 06:45 AM
BigCat3153
Aug 19, 2011 09:08 AM
