I need help finding a decent price TCM ???
Old Oct 21, 2010 | 05:26 PM
adygsxr's Avatar
Default I need help finding a decent price TCM ???
I tried starting this morning my x-type to find out that it cranks over but won't start, gives me trany fault and pecus e error, hook it up to a computer got P0603 code, tried resetting it no luck, if anyone knows where I can find a decent priced tcm pls let me know, so far the cheapest one I found was $695.00.
Old Oct 21, 2010 | 05:44 PM
benebob's Avatar
ud
Did you check out www.car-part.com
Old Oct 21, 2010 | 09:30 PM
motorcarman's Avatar
It would help to know what EXACT vehicle you have (MAKE,MODEL,YEAR)
P0603 is for an ECM failure, not a TCM
P0603 EMS
OBD II
ECM Keep alive memory error
Monitoring conditions:
Engine temperature cool
(cooling fans not running)
Remove ignition key for 20
seconds (cooling fans not
running)
Ignition key in, position II for 5
seconds (do not start)
Repeat cycle two additional
times.
Default Action
NONE
POSSIBLE CAUSES
ECM Failure
Could just be a power fault or wiring issue.
bob gauff
Old Nov 14, 2012 | 10:52 AM
Jaggrnxk8's Avatar
Default PCM KAM error
I just got the same code (P0603) for my 2004 XK8. Engine starts and seems to run fine, but check engine light on. Generic code says could be battery terminals or charge. Have had the car for 6 years and don't think I've ever changed the battery (have to check my records when I get home). Could this be an early indication of battery failure (happened before when I let the car sit for a while - checked the battery connections & cleared the code - went probably 6 months without light), or an ECM/PCM failure?
Wolfy
May 28, 2024 08:06 AM
XJsc-guy
Sep 25, 2015 11:09 AM
luc891
XE ( X760 )
Sep 15, 2015 12:30 AM
uncheel
Sep 5, 2015 01:34 PM
Jaguar Forums Editor
Jaguar Press release
Sep 3, 2015 09:38 AM
