I think I need a new waterpump.
Old Aug 24, 2010 | 12:19 PM
Elrod the Albino's Avatar
Default I think I need a new waterpump.
When I had my fuel pump replaced several months ago, the guys who did it said that I would probably need a new waterpump soon, but not immediately as it seemed to be leaking a bit. It drove fine but I am noticing that it is starting to visibly leak now and need to be refilled, Obviously it is time to rectify this.
A quick book estimate from a Goodyear told me it would be about $350.
Is that right? I thought a water pump was an easy fix. Is this the sort of thing I could do myself? (I'm not an idiot, but I'm not super skilled and have basic tools.) Also, is there any particular pump I should/can use?
Old Aug 24, 2010 | 01:04 PM
Brutal's Avatar
Its easy. Take out the battery and batt box and its right there. 6 or so 8mm bolts later plus the 3 on the cam sprocket
Old Aug 24, 2010 | 03:59 PM
It can't be that easy can it? I never have such luck.
My last two "easy" fixes ended with me replacing my IT O-rings, only to find I need a new fuel pump, then my flat tire ended with a Goodyear sawing my studs off.
Old Aug 24, 2010 | 06:18 PM
Brutal's Avatar
with that kind of luck maybe a bicycle would be better
its easy
Old Aug 26, 2010 | 01:48 AM
Well I just did it. i drove it around the block several times and I think everything is okay. The real test will be my trip to work tomorrw. Hopefully I did everything right. Thanks Brutal. You may have saved me $300. (we'll see tomorrow if I jacked it all up and it will now cost more, lol.)
Roadhogg
Jan 22, 2016 05:47 AM
supra-raleigh
XJ40 ( XJ81 )
Sep 23, 2014 10:30 AM
jamdmyers
Nov 14, 2013 06:45 AM
Stypehooligan
Sep 6, 2013 02:45 PM
azblindguy
Feb 16, 2013 10:19 PM
