IDS software V130 system requirements
Old Feb 16, 2018 | 03:53 PM
wa3ra's Avatar
Default IDS software V130 system requirements
I guess the google-fu is weak with this one today!
Does anybody know the minimum system requirements for the IDS software version 130?
I plan on dedicating a laptop to the task, since the USB boot drive that I was using has gone tango uniform. I still have the software, but it is a pain to reboot the machine that I'm currently using, and I figure I'll pick up an old (read: cheap) laptop with XP SP3 to run it directly...but I have no idea what the minimum specs are...except that I know I need USB2 for the Mongoose.
Any ideas?
Old Feb 16, 2018 | 04:14 PM
Dell Gailey's Avatar
https://www.fordtechservice.dealerco...quirements.asp
Old Feb 16, 2018 | 04:20 PM
https://www.jaguarforums.com/forum/a...s2_jag_vci.pdf
Old Feb 16, 2018 | 04:22 PM
wa3ra's Avatar
For the 130, Dell...Those are the specs for the "ET PHONE HOME" V145 that I'm running on the Win 7 box.
I know I need Win XP SP2 or SP3, but don't know the memory or processor speed that I need...but a big Thanks, anyway!
The late-model SDD id overkill; I just need to program some options and modules, so the IDS will do the job just fine!
https://www.jaguarforums.com/forum/s...e-help-191597/
Old Feb 16, 2018 | 04:40 PM
wa3ra's Avatar
I have a Drewtech Mongoose interface by the way.
Old Feb 16, 2018 | 04:41 PM
Found minimums in a blog post =
Unless noted otherwise by contributors, it is assumed that a PC laptop platform which meets the following minimal specs, is required ...
modest <1GHz P3 cpu, with about 1Gb RAM;
HDD of say 80Gb ... partitioned 20+60Gb ... the former for o/s and latter for data;
inbuilt SD Card Reader loaded with 32Gb micro SDs;
readily replaceable battery pack, 12VDC cig charger, and readily replaceable BIOS nvram battery;
operating system must be XP PRO SP3, (or later running in XP mode?);
software tools to include Adobe Reader, and not much else;
onto this platform, we bring our Jag diagnostic s/w and compendium of PDF reference files.
I will start to build a table of all known modules and functionality, which I will insert here as an attachment, then update by edit as contributors post.
Old Feb 16, 2018 | 04:43 PM
Additionally =
Thanks to some great help from a forum member called bigbear, (http://www.jaguarforum.co.uk/members/bigbear/) and Police666's documentation, I now have a laptop, Mangoose and SDD V1.30 (with IDS) all working lovely. I used an old Lenovo R60 I had hanging around, 1.66Ghz centreno with 2Gig of RAM and a 60Gig HD
Old Feb 16, 2018 | 05:18 PM
wa3ra's Avatar
Kicking myself for ditching the old Dells now, but I have a line on a decent Toughbook for "cheap". I do have a clean licensed copy of 1.30 here, so we'll see how we do...everything already paid for itself on the 2002, where I actually had to flash the ECM...laptop plugged in, and a big Astron power supply floated across the battery. I was amazed at how much power the modules alone used under the SDD!
Old Feb 18, 2018 | 05:36 PM
wa3ra's Avatar
Found a decent Toughbook for a reasonable price, so I'll have a dedicated 'puter!
All in, about the cost of 3 hours of dealer time, so it will pay for itself in short order.
Old Feb 19, 2018 | 04:32 AM
Well, that depends, after you drive to Utah to do mine, it may not be as economical as you assume :-) :-) :-)
Old Feb 19, 2018 | 05:10 PM
wa3ra's Avatar
Dandi
General Tech Help
Oct 27, 2022 07:40 AM
sayitaintso
Jan 29, 2018 07:04 PM
RDMinor
General Tech Help
Mar 1, 2015 09:22 PM
12jagmark
Feb 28, 2015 11:34 AM
