Immobilizer and engine not turning
Old Dec 22, 2015 | 02:30 PM
NW1996's Avatar
Angry Immobilizer and engine not turning
Just did an engine change on my cat 2.5 V6 and everything bolted on all cables plugged in all happy until I go to the front put the key in ignition everything as it should I turn the key to start it aaaannnnndddddd NOTHING HAPPENS, well annoyed but shortly after I realize that the Red Alarm Light is constantly on and after a few seconds it flashes, from what I understand it flashes code 24(flashes 2 times the pause and flashes 4 time and stops and re does the sequence) could anyone advice what to do now???
Old Dec 23, 2015 | 02:44 AM
JagV8's Avatar
In common with others across the years I can't find that code. Be sure it is 24 because you'll be down many wrong alleys if not!
I did find that it might be a CAN fault. Possibly a missing terminating resistor. (Should be one in the PCM and the other in the ICM - see workshop manual.)
Old Dec 23, 2015 | 06:42 AM
santer's Avatar
This has the flowchart
http://www.bluejag.co.uk/Jaguar-XT-T...t%20System.pdf
" Engine cranks but will not start
If the engine is cranking it means that the ECM is enabled with respect to PATS.
If PATS was disabled the ECM would not engage the starter.
This could be confirmed by verifying the PATS LED prove-out (illuminated solid for 3 seconds) or by
reading Diagnostic Trouble Codes (DTCs) from the instrument cluster and ECM "
Old Dec 23, 2015 | 10:03 AM
joesoap's Avatar
Manual or Auto?
If auto could it be on inhibit from Trans?
If manual I would backtrack on all connections (engine earths) particularly around starter and or fuses/relays.
Old Dec 23, 2015 | 11:54 AM
NW1996's Avatar
thanks guys will definitely give everything a try and plug in a code reader and see what it comes up with, got a few other jobs to do but as soon as I know something will update
Old Dec 24, 2015 | 01:15 AM
JagV8's Avatar
If it's the CAN terminator then you'll need a DVOM and I suspect an OBD tool won't be able to read any CAN data.
Old Dec 25, 2015 | 04:48 PM
NW1996's Avatar
so if it is the can terminator how do I test it with DVOM??
Old Dec 26, 2015 | 09:55 AM
JagV8's Avatar
Everything switched off, CAN (a worldwide standard https://en.wikipedia.org/wiki/CAN_bus) should be 60ohm.
Old Jan 1, 2016 | 06:52 PM
Larry-Cleveland's Avatar
Very interesting read, thanks. Takes me back to the old Novel coax network cable with a terminating resistor on each end of the cable run.
So where are the resistors located?
What items are on the CAN Buss?
Old Jan 2, 2016 | 03:45 AM
JagV8's Avatar
See free download workshop manual / elec. guide.
Old Dec 22, 2019 | 05:46 PM
DrJagerCola's Avatar
There was never a followup with code 24, which I've seen in three instances now.
I will follow up on my Solenoid, ECM, No Start thread with JagV8 and others as we work through this issue.
NW1996, are you still around?
Old Dec 23, 2019 | 04:34 AM
Dell Gailey's Avatar
@Drjag, his last post was 37 months ago and I have never run into or seen him here in my time in the forum.
Code 24 =
https://www.justanswer.com/jaguar/3m...esel-when.html
Old Dec 23, 2019 | 10:45 AM
Hi, that's another good link and I read through it. However, my reading was 600 ohms and so it isn't necessarily pointing to the connection between CANbus and ECM.
Here is my Post: https://www.jaguarforums.com/forum/s...5/#post2170193
I will try to narrow it down and post the solution when I'm finished.
Wolfy
Dec 25, 2015 09:44 PM
Racer X
Dec 13, 2015 05:51 PM
x type diesel
Dec 9, 2015 05:40 PM
SD96XJ6L
Dec 1, 2015 02:49 PM
Collector1
Nov 28, 2015 05:12 AM
