Interior lining
Old Oct 23, 2013 | 11:08 AM
joec's Avatar
Default Interior lining
I the interior lining ( the material like the headliner ) on the left and right side of the windshield is coming loose on the windshield side. I believe I understand this is common on 2004 x-type, not sure of other models or years. I would like to fix it up. Is something easily done? Any tips / tricks? Recommendations for having it fixed professionally or not? Any round about pricing from outside? If it's easy enough I'd rather do it myself.
Old Oct 23, 2013 | 11:29 AM
Jac's Avatar
Jac
I've never had this problem but this might help you: https://www.jaguarforums.com/forum/x...adliner-65935/
Old Oct 23, 2013 | 11:58 AM
joec's Avatar
Thanks!
Old Oct 23, 2013 | 03:26 PM
sov211's Avatar
you can recover these panels yourself; the panels just (gently) pull away from the pillar but there is a clip on a chord that holds them so this must be disengaged. Obvious once you pull the panel. You strip the damaged fabric and replace with new, glued on. It is a very tight fit at the base where it meets the windshield, but there will be no problem.
Old Oct 23, 2013 | 09:40 PM
joec's Avatar
Great! Will give it a shot this weekend! Thanks!
Old Oct 26, 2013 | 07:35 PM
Pacobell's Avatar
My headliner is starting to unglue across the top of the windshield and both front pillars. But for a car in Florida almost seven years old, I would expect this about now. I'm not going to mess with it until after my transfer case or prop shaft noise issue gets solved. (Wishful thinking. . .)
Old Nov 2, 2013 | 09:18 AM
Xerxes' Jag's Avatar
Pacobell, check out this site Tampa Mobile Headliners | Headliner Repair, Headliner Replacement I just got mine done. See my post from today.
Old Nov 5, 2013 | 09:26 PM
Pacobell's Avatar
Who would have thunk it? My wife went back to her craft room and got a can of Elmer' s Craft Bond spray adhesive and fixed the headliner where it was peeling off above the windshield and on both pillars. It's holding like a dream and you wouldn't have known there was ever a problem. You can get this at Wal-Mart in the craft section. Next weekend I will give her a crack at fixing my transfer case!
silkcat
Jan 18, 2025 04:29 AM
42Ajd
Dec 30, 2015 09:45 AM
tampamark
Sep 14, 2015 09:12 PM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
1964Daimler
Sep 9, 2015 11:28 AM
