iPhone to Xtype
Old Aug 31, 2009 | 04:07 PM
pu5hkar's Avatar
Default iPhone to Xtype
Hey guys,
Just bought the iphone and wanted to know what i could do to hook this up to the car.. keeping in mind that i want good quality and not the damn radio frequency hook up.
1. Additionally, in the past, i had sub woofer connection, and believe that i have the adapter/converter from the stock head unit to the amp... those rca things... perhaps ill be able to use that?
Thanks guys!!!
Old Aug 31, 2009 | 06:27 PM
JagXType620's Avatar
I have my iPhone connected through my Kenwood headunit.... Might be something you want to look into instead of getting ripped by the dealership to put one in for you, you can put a tv in your car as well...
Old Aug 31, 2009 | 09:57 PM
pu5hkar's Avatar
nah im keeping my **** stock. first time i didnt have tv's n all that in car. NO AFTERMARKET!
Old Sep 1, 2009 | 01:00 PM
Jagtech's Avatar
Just go to your local dealer and ask for the Ipod connector kit. its not cheap and the dealer has to install it. but not sure if it will work with iphone but i did have it work with a itouch.
Old Sep 1, 2009 | 03:15 PM
pu5hkar's Avatar
yeesh thats the only way? thats wack...
Old Sep 1, 2009 | 03:36 PM
gupdah's Avatar
Iv had an iphone for quite a while and iv been wanting to hook up the acm also. But its toooo expensive. i have a belkin fm transmitter that works okay, radio quailtiy, a bit worse... rarely use it.
gupta
Old Sep 1, 2009 | 04:46 PM
krisleslie's Avatar
On my iPhone 3GS and iPhone 2.5G I still use the good old cassette adapter. It's better than the FM Transmitter by 100x but it still isn't a great solution. I'd had some ideas but they would require some modification to the center console probably.
Old Sep 2, 2009 | 02:18 PM
TX_Jag's Avatar
I was looking for a way to have an Aux input that would also satisfy an iPhone.
I bought the Dynex WIRED FM modulator kit at Best Buy for $45 and installed it myself. I needed 2 antenna adapters for $12 each. There is one + and one - wire and it switches itself on and off automatically.
The head units in our cars are very easy to get out.
I must say, it is VERY clear. No background noise, no interferance, no squeal...I'm really happy with it.
I routed the 3.5mm Aux in port into the glove box.
Hope this helps!
Finbarr1975
Oct 4, 2015 05:32 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
Msteiner
Audio/Visual Electronics
Sep 30, 2015 08:36 AM
BlakeConverse
Sep 28, 2015 02:22 PM
1LowCat
Sep 14, 2015 07:51 PM
