iSimple IS77 install question/problem
Old Jan 23, 2013 | 06:50 PM
Bdg6065's Avatar
Default iSimple IS77 install question/problem
Hi all, I installed an iSimple fm transmitter about two weeks ago and all was working good until recently. Yesterday it was playing my iPhone music fine, then it went dead, just static and no charging. I turned it off then later when I got in the car turned it on and worked fine again, after 10 minutes or so, same issue no power to the device and static. Today same thing works fine for a bit then shuts off. Now here is my question, I installed this myself and wired it to the cigarette lighter. (Keyed power source) do y'all think this could be the issue or is it a bad unit? Thanks for any help
Old Jan 23, 2013 | 08:02 PM
Thermo's Avatar
Veteran: Navy
bdg, from what you are describing, it sounds like you are not getting good electrical connection. How did you attach the wires to the connectors on the cigarette lighter?
Old Jan 23, 2013 | 08:57 PM
Bdg6065's Avatar
Thermo,
I used a quick splice connector. I thought maybe it was a bad connection but there is no rhyme or reason to when the power goes out. the vehicle could be in motion or at a stop. think bad connection?
Attached Thumbnails iSimple IS77 install question/problem-500-pcs-lot-scotch-locks-quick-font-b-splice-b-font-font-b-electrical-b-font.jpg
Old Jan 24, 2013 | 04:39 AM
flyrr100's Avatar
Where did you earth it? I used to have an FM Modulator and used one of the J Gate screws. Also used the lighter and never had a problem.
aholbro1
Dec 29, 2024 06:46 PM
H20boy
Dec 24, 2024 03:23 PM
philwarner
44
Nov 5, 2024 06:29 PM
Majik Lasers
Aug 2, 2024 01:49 AM
Dagny
Jun 11, 2024 01:06 PM
