Jaguar X-type automatic transmission problem
Old Jun 13, 2018 | 08:56 AM
mittel's Avatar
Default Jaguar X-type automatic transmission problem
Hello everybody,
I have a Jaguar X-type 2.0 v6 from 2003 with the 5 gear transmission, but there is a big problem.
The gears 4, 5 and R won´t go.
What could be the problem?
Additionally the ABS lamp lights and the stability controll has an error.
Is there maybe a connection between?
Maybe someone can help me?
Old Jun 14, 2018 | 04:11 PM
JonK's Avatar
I had exactly this issue with a previous BMW 330i auto.
It was a reluctor ring/wheel sensor issue.
You’ll need to run a diagnostic check and read the fault codes.
Old Jun 15, 2018 | 12:30 AM
mittel's Avatar
Default Thank you very much.
But how can I check the wheel sensors by my self with out reading out fault codes?
Old Jun 15, 2018 | 12:34 AM
JonK's Avatar
In my opinion, only by lengthy process of elimination and getting a car on a ramp or inspection pit to take a look.
if you possibly can, my advice would be to get it to a garage and have them read the codes or to buy the little box of tricks (which I think are fairly cheap these days) and have a go yourself.
Otherwise these symptoms could reflect any number of things, particularly if it’s something electrical.
Old Jun 30, 2018 | 07:24 AM
mittel's Avatar
I bought a device to read out the fault codes.
First I cleard all codes. Then I drove a little bit, and know there are two codes :
P0733 and P0734 incorrect ratio.
Old Jun 30, 2018 | 05:13 PM
Dell Gailey's Avatar
https://www.jaguarforums.com/forum/x...ion-help-4902/
https://www.jaguarforums.com/forum/x...problem-89372/
check last post here =
https://www.jaguarforums.com/forum/x...-0l-awd-35869/
Search is a marvelous tool here.....
Old Jul 4, 2018 | 07:33 AM
mittel's Avatar
I already searched the whole forum...
Maybe anyone know what this codes have to do with the reverse gear, because when I go into reverse it is like neutral.
But when I do the car on a ramp, so that the wheels can turn free and go in reverse, the wheels turn correctly, only that no force is transmitted. It's like the clutch is not closing.
Old Jul 4, 2018 | 04:09 PM
Ok, ignore the links, keep asking questions.....
Old Jul 5, 2018 | 01:18 AM
mittel's Avatar
I have already searched in all threeds here, also in your links, before you wrote it.
Sorry, but I will answers of those who can say what I could try to do know to get the car driving in reverse.
Jaguarsmg1
Jan 16, 2017 04:34 AM
dzejraf
Dec 9, 2016 02:57 PM
gvpierce
Apr 24, 2013 01:53 PM
eugene1175
Feb 16, 2010 07:43 AM
