Jaguar x type headlight system
Old May 12, 2018 | 12:01 PM
Braydon's Avatar
Default Jaguar x type headlight system
Hey my headlights and dash lights are always on while my car is on even though the switch is in the off position they stay on until I turn the car off. Are they supposed to stay on or could there be some kind off wiring issue with the switch?
Old May 12, 2018 | 12:55 PM
sov211's Avatar
You do not indicate where you are (nor any other helpful information). If you are in Canada or elsewhere but have a Canadian market car then yes, depending on model year, the headlamps and every other exterior lamp will be on, always -and the dash lights too. This applies to the 2002 to 2004? cars. By 2005 the system still has all exterior lights on always, but not the dash lights (because this makes the display dimmer and more difficult to see in daylight). All of this is a product of the daytime running light system mandated by Canadian law, and it is perfectly normal. If your car is one of the early models mentioned, it means that you never have to touch the light switch.
Old May 12, 2018 | 02:10 PM
Braydon's Avatar
Hey thanks yea I live in Canada and have an 2003 x type. so that means my headlight system is used for daytime and night time lights then?
Old May 12, 2018 | 02:11 PM
Jag4's Avatar
Sorry for the lack of market detail, and I thought my signature vehicle detaildeta included.
​​​​​​The interface issueihas since been resolved.
Thanks forum!!
Old May 12, 2018 | 04:01 PM
Thermo's Avatar
Veteran: Navy
Braydon, yes. In short, Jaguar has 3 different headlight switches that they use for various markets. In your case, since your car was intended for Canada, it has the canadian headlight switch (the 2 others are Scandinavian (headlights work in the OFF and ON positions, but off in the parking light position) and the non-DRL version (ie, headlights off unless in the ON or AUTO position, side lights on in any position than off).
Old May 12, 2018 | 06:06 PM
sov211's Avatar
Yes - your lights, ALL your lights, are on all the time - that is correct for your Canadian car. You never need to touch the light switch unless you need to turn on the front or rear fog lamps. But your car is a Jaguar, not a BMW, so you won't be using the blinding fog lamps unless there is fog, right?
Beagle
Dec 4, 2015 02:27 PM
Anfield Dreaming
May 4, 2015 12:34 PM
jagosaurus
Oct 3, 2012 01:51 AM
ln69bt
Sep 4, 2012 04:30 AM
androulakis
Dec 4, 2009 05:51 AM
