Key Stuck and Shifter Wont Go Shift down to 4, 3, or 2...Please Help!
Old Mar 31, 2007 | 03:02 PM
racerx82's Avatar
Default RE: Key Stuck and Shifter Wont Go Shift down to 4, 3, or 2...Please Help!
Didn't you test drive it before buying?
Old Apr 1, 2007 | 11:32 AM
racerx82's Avatar
Sounds like the transmission cable/linkage is stuck. One possible problem is that the transmission valve body is damaged for those gears. Check your linkage in the console first
As for your key issuse, i'm not sure what the battery has to do with it..the key is a normal tumbler/lock...the battery has nothing to do with it....
When you forcd your transmission into 4th and radiator fluid came out, it was just a coincidence.
You have 30 days from the purchase of your car to get everything fixed?? I would take it back and see if they can help you. Sounds like you may have problems down the road.
Old Apr 1, 2007 | 11:39 AM
bigdreams05's Avatar
Race, It's not coolant that came out under the hood...it was tranny fluid. In General Tech Chat, he wrote that the liquid was red and oily, not pinkish like coolant. I think that forcing it into 4th might have caused that problem.
Old Apr 1, 2007 | 04:33 PM
jaja, I like that!
Old Apr 1, 2007 | 08:28 PM
ORIGINAL: ejrry85
The mechanics are going to try to screw me harder just because they think I'm rich.
J-A-G-U-A-R
Just A Guess U Are Rich
Bloody need 2 be to run one of these babies...............lol
JC
Rlover
Mar 30, 2016 10:04 PM
neruda
Oct 18, 2015 01:19 PM
Roger95
Sep 25, 2015 02:05 PM
GGabriel
Sep 18, 2015 08:44 PM
Sprayall
Sep 3, 2015 07:49 PM
