Knock sensor 2 low voltage error
Old 09-16-2020, 01:13 PM
Valkyrie2001's Avatar
Default Knock sensor 2 low voltage error
Got a rather strange problem with my 2006 X type in that it is getting a knock sensor 2 low voltage error. The car goes into limp mode and doesn't want to run above 3,000 RPM. What's strange is I can clear the code and drive her say 100 miles and the check engine light never comes on. But if I stop the engine then start her again there it is, knock sensor 2 error. Also, during the winter months when it is cold I can reset the code and it doesn't come back until the weather starts getting warm again. One bad thing here in Kansas is that our premium gas has 10% ethanol in it. Any ideas on what might be causing this since it is so intermittent?
Old 09-16-2020, 04:06 PM
JagV8's Avatar
Received 4,489 Likes on 3,906 Posts
By law many codes are 2-trip so cannot flag until you turn the car off as you describe, even though the fault is there. It's a well-intentioned law which works well almost all the time but does in rare cases lead to anomalies as in your post.
Fix it!
Stacey H
11-24-2019 07:39 PM
Carnival Kid
03-17-2018 06:17 AM
XKR_Ben
08-23-2017 04:40 PM
Darcy Nelson
06-17-2017 01:01 PM
marktmv
02-13-2013 09:06 AM
Quick Reply: Knock sensor 2 low voltage error
