Knock sensor fault??
Old Nov 2, 2014 | 12:41 PM
mickyw12's Avatar
Default Knock sensor fault??
Hi all i have an 2002 x type 2.5 v6 i had the engine management light come up i read the code it was showing knock sensor ! so i changed the knock sensor problem solved or so i thought !! i done 10 miles with no problems then the car went to limp mode again saying knock sensor again grrr .. if i clear the fault it wont go into limp mode until it goes to normal temreture then the light comes on and it again shows knock sensor fault !! the car dont knock at all it sounds sweet . has anyone got any ideas ?? could it be plugs ?? or something else ?? cheers in advance ,
Old Nov 4, 2014 | 07:54 AM
Dr dome's Avatar
Default 2 knock sensors
There are 2 knock sensors on the car. Which one did you change out. There is the hidden one in the center of the engine, under the lower intake and under the steel coolant pipe. The other is on the side of the engine. Let me know if you need locations of both and I will get pictures
Good luck,
The Dr!
Old Nov 4, 2014 | 07:04 PM
ltmax's Avatar
I bet it's the one under the intake manifold that's bad. Mine failed at 130k.
Old Nov 5, 2014 | 06:11 AM
mickyw12's Avatar
Good luck,
The Dr!
Mines a 2002 2.5 x type ive been told there is only one knock sensor on this model its the one under the thermostat housing under the injectors thats the one i have changed .
Old Nov 5, 2014 | 06:13 AM
mickyw12's Avatar
Yes thats the one i changed ive been told thats the only one on it !
mrplow58
Jan 21, 2024 05:53 AM
roman_mg
Feb 8, 2016 01:30 AM
shootingbrake
Sep 23, 2015 10:54 AM
JagBrian
Sep 21, 2015 07:17 PM
Bob Gelston
Sep 14, 2015 11:08 PM
