leaking oil pan gasket
Old Sep 27, 2009 | 08:28 PM
boz86's Avatar
Default leaking oil pan gasket
Went in planning on drilling the transfer case as others have done. Found one bolt on the pan a little loose, took a chance and tightened it. So far, so good, a tank of gas later and it's not leaking.
Was a really small leak so I'm hoping I get lucky.
Wonder how hard it would be to replace the gasket the right way?
Old Sep 28, 2009 | 06:49 AM
Thermo's Avatar
Veteran: Navy
Boz, from what people have said, plan on taking about 10 hours or so. There is a lot of collateral stuff that needs to come off in order to access the bolts for the oil pan. I would say that as long as you are not leaking, call it good enough. Sounds like you got lucky and simply had a bolt to come loose. Smile and move on.
Old Sep 28, 2009 | 07:08 AM
boz86's Avatar
Thanks, got to get the manual downloaded so I can get step by step instructions. Just spent 10-11 hours dropping and reinstalling a tranny/transfer case in a Ford F150 to get at the rear main seal.
Really hoping this simpler fix works because that was a LOT of work :-)
aholbro1
Dec 29, 2024 06:46 PM
tomsjag
Jun 10, 2023 10:02 AM
Jandreu
Jun 30, 2022 03:10 PM
kelliott
May 31, 2022 05:26 PM
Dymaxxion
Sep 4, 2015 02:40 PM
