Maintenance - Control arm bushings
Old Jun 11, 2018 | 09:28 AM
Jag4's Avatar
Default Maintenance - Control arm bushings
Hi forum -
Last year, while replacing my suspension, I replaced most control arms and sway bar linkage. When I asked my mechanic if the front lower control arm bushings needed replacing, he said no, that they looked fine.
I need to drop the front sub-frame again, this time to install a new sway bar and bushings, and am considering replacing the front lower control arm bushings (I'd replace the whole arm), in spite of what my mechanic said. I find it hard to believe that all the other suspension bushings were toast (and clearly they were toast) but that this arm bushings are fine. Is my thinking wrong here?
Anything else I should do while I have the sub-frame down, such as motor mounts? (I'd like to keep this car for a while.)
Old Jun 11, 2018 | 05:54 PM
Dell Gailey's Avatar
My "A frame/ball joint" looked good on passenger side and all rubber was toast when I removed it as the driver's side was squeaking and did both for good measure.
Here's the best advice I got from a member in replacing this part. When you drop the sub frame REVERSE the bolts on the arm so you never have to drop the sub frame again. Mine turned into a nightmare with the "captive nut" within the body that the subframe bolt tightens into broke free and couldn't be removed. I documented it in another post if interested.
Reverse this bolt from bottom up with NUT on top.
rabbits2
Aug 21, 2011 01:46 PM
MTZGR777
Feb 16, 2010 04:25 PM
pantheon
Nov 8, 2009 02:44 PM
DornB
May 18, 2009 06:19 PM
Tomlite
May 12, 2008 05:18 PM
