Manual Gaiter/Shift Boot change - RESOLVED
Old Apr 15, 2010 | 11:16 PM
Jerry the Jaguar's Avatar
Default Manual Gaiter/Shift Boot change - RESOLVED
Can anyone tell me how to change the leather gaiter/shift boot on my 5-speed?
Last edited by GGG; Sep 4, 2012 at 02:51 AM. Reason: add 'RESOLVED' to thread title
Old Apr 17, 2010 | 02:20 PM
Nevermind i did it.
Old Sep 3, 2012 | 02:09 PM
BillAdama's Avatar
Originally Posted by Jerry the Jaguar
Nevermind i did it.
So what's the secret? Looking to do it myself
Old Sep 3, 2012 | 03:32 PM
Aonsaithya's Avatar
Leather Gaiters ("Boots")
I think there's a thread with photos and everything either here or on Jaguarforum.co.uk but couldn't find it.
Old Sep 4, 2012 | 12:46 AM
Emanx2.5's Avatar
Did mine a few months back, replaced it with genuine Italian leather. Also changed the hand brake too looks way better.
JAGUAR X-TYPE INSTALLATION INSTRUCTIONS
1. Unscrew the shift knob (lefty loosey), it’s quite tight but will unscrew.
2. Open the ashtray and gently pull the plastic shift boot frame from the center console at the 4 attachment points are shown below. Lift the front of the surround off, then slide your fingers back and lift the back of the surround off.
3. Pull the boot up over the shift lever (inside out) and cut the plastic tie wrap holding the boot to the lever.
4. Snip the staples holding the boot between the inner and outer frame.
5. Insert inner frame inside shift boot.
6. Set boot and inner frame into outer frame and re-staple from the bottom, then bend staple prongs over (I recommend a backboard to staple against – even into – which can then be removed so you can bend the prongs over). Alternatively, you could drill some holes through both pieces and pop-rivet them together.
7. Insert boot and frame over shift lever – the sewn-in elastic band replaces plastic tie wrap – and snap in place on console.
8. Reinstall shift knob (righty tighty) and enjoy the new boot!.
Useful tip
You have installed a product made out of genuine leather. As you know, to maintain a leather product in good condition, you should take care of it. We suggest occasionally (every 4-6 week for example) applying some leather conditioner/UV protector to keep your leather from drying up in the sun and cracking.
Old Sep 4, 2012 | 02:47 AM
Originally Posted by Emanx2.5
Did mine a few months back, replaced it with genuine Italian leather. Also changed the hand brake too looks way better....................
Great pic sequence.
The Italian leather boot looks much better.
Old Nov 8, 2015 | 01:23 PM
brichardsonhome's Avatar
Default Thanks
Thanks for the gaiter instructions guys, much appreciated. Brian
Old May 31, 2017 | 02:16 PM
dotcomjohnny's Avatar
Thanks to Emanx2.5. Searched YouTube for a solution, but found none.
This is just what I've been looking for, great write up and pictures. Many thanks.
Old May 31, 2017 | 03:11 PM
DUNKS's Avatar
Hi. I heard a tip which seems sensible. When removing the old gaiter cut it round it's edge and remove the centre fabric. The side frame is easier to remove from the inside. less chance of breaking it.
Forcedair1
Sep 8, 2025 01:57 PM
dsnyder586
Dec 29, 2024 07:39 PM
H20boy
Dec 24, 2024 03:23 PM
ZJag
26
Sep 5, 2016 03:33 PM
aarahim
Sep 7, 2015 03:12 AM
