Misfire
Old Nov 29, 2015 | 12:53 PM
topanga's Avatar
Default Misfire
My X has it's first running fault. Yesterday could feel a slight misfire, then EML light on, managed to get home ok and today read the codes.
P0301 - Misfire Detected in no1 Cylinder
P1313 - P1313 Misfire Rate Catalyst Damage Fault
I have checked the PCV pipe and it seems ok, I then cleared the codes. When I restarted, the EML is on again but no new codes stored and also the red transmission light come on and car is jolting when I put it into drive and doesn't seem like it would accelerate.
Would a misfire cause the transmission light to come on?
Thanks for any help.
Old Nov 29, 2015 | 09:08 PM
iownme's Avatar
As #1 cylinder is easily accesible, the first thing to do is check the coil connection to #1 cylinder.. If it looks good and electrical wiring looks good, remove the coil connector then remove the spark plug and inspect that.
Old Nov 30, 2015 | 01:34 AM
topanga's Avatar
Thanks, but isn't no1 cylinder underneath the inlet manifold? But that will be my plan when I get chance to do it later in the week.
Old Nov 30, 2015 | 02:17 AM
JagV8's Avatar
Any misfire can cause enough hassle to upset the trans. Fix misfire and trans probably happy again.
Note that P1313. Don't keep letting misfires happen!
If #1 is awkward to get at I'd get a good coil and swap it in. Unless your plugs are due changing I'd be surprised if it's a plug fault.
If they are due, do 'em while it's apart.
Old Nov 30, 2015 | 02:32 AM
topanga's Avatar
Thanks JagV8. I changed the plugs at 72k and it's now done 100k. I might swap the plugs and no1 coil around from front to back to see if the misfire code changes.
Old Nov 30, 2015 | 06:13 AM
iownme's Avatar
Yes, my mistake... Sorry, lol
Rear bank far leftside plug
1 3 5
2 4 6
Old Dec 5, 2015 | 06:12 AM
topanga's Avatar
Update - Read the live data from the scanner and initially had high fuel trim readings which went to zero (ish) at 2000rpm so thought air leak. The PCV pipe rubber seemed a little soft but no splits so replaced it anyway. Re started car and was as smooth as a nut but it has a slight hesitation every now and again and gearbox light keeps coming on (no engine light this time) so i can't drive it. Fuel trims are fine:
SHRTFT1 0
LONGFT1 -0.8
SHRTFT2 -0.8
LONGFT2 -3.9
MAP Pressure is 9.2inHG and fuel pressure 54.8psi, so i seem to have sorted the air leak but why is the gearbox light coming on and why the occasional hesitaion? Any help appreciated.
Old Dec 5, 2015 | 07:19 AM
dwclapp's Avatar
topanga: Just spitballing...... Check the electrical connector at the bottom, front of the throttle body. It's prone to become brittle with heat & age, sometimes causing an intermittent connection. It's not a problem until you disturb it, e.g. while looking for a vacuum leak.
Sometimes you can stabilize it with a nylon zip tie or epoxy, sometimes you need to replace the connector. It's a standard Ford to Denso connector, Motorcraft WPT-1269, shown here: https://www.jaguarforums.com/forum/x...5/#post1340696
Old Dec 5, 2015 | 08:09 AM
topanga's Avatar
Thanks dwclapp, I'll take a look at that before it goes dark.
When I switched it off earlier the gearbox light was on. Just been out to it again, no light, running really well and been for a short drive, so far so good. Will take it for a longer drive later and report back.
Old Dec 6, 2015 | 10:06 AM
JagV8's Avatar
With luck it may just be relearning that the fuelling is as it should have been but wasn't.
Old Dec 6, 2015 | 11:41 AM
dwclapp's Avatar
To build on JagV8's suggestion, you can make the ECM re-learn faster by disconnecting the positive battery cable from the battery post and holding it against the negative battery post or any ground point for a few moments. Then reconnect the positive cable to the positive battery post and drive as you normally would while the ECM relearns how to re-optimize engine parameters like fuel trim, timing & throttle position.
Old Dec 6, 2015 | 02:43 PM
topanga's Avatar
I did disconnect the battery for a couple of hours but didn't touch the leads together. It does seem to have made a difference though. When I restarted it, I left it to idle until the temp gauge got to half way, then went for a gentle drive. Been out today also, 85 miles later, no lights and I swear the engine idles smoother than before and at slightly lower revs. Thanks for all the advice chaps.
Old Dec 7, 2015 | 01:48 AM
JagV8's Avatar
Sounding good!
Sean W
Dec 3, 2015 07:47 AM
Msloescher
Dec 2, 2015 04:47 PM
philwarner
Dec 2, 2015 01:25 PM
mkprator
Nov 30, 2015 06:58 PM
XJLFTW
Nov 27, 2015 05:03 AM
