Model year for spares.....
Old Apr 1, 2024 | 06:23 PM
Guitar_Tech's Avatar
Default Model year for spares.....
With a VIN of SAJKG54S28YJ30759 giving the years as 2008 even though it could have been made from Sep 2007 onward
Do I assume that any spares needed will be for a 2008 model?
Like the drivers side door handle cable?
2001-2007 it is given as 68cm,
Where as 2007-2010 is given as 64.5cm.
Thanks in advance
G
Old Apr 3, 2024 | 01:59 PM
As no one seems to know I'll take the chance and where there is a choice, I'll go for the later (2008 and onward) recommended item.
G
Old Apr 5, 2024 | 02:25 AM
Peter_of_Australia's Avatar
I dare say, if you know the 2 part-numbers, which you have to choose from, the solution might be to enter those P/Ns e.g. into:
https://www.britishparts.co.uk/classic-jaguar
And hopefully they tell you for each P/N, where it belongs.
Other than thet:
Can you measure on your old cable, what the length was (even if that is broken off, estimate how long it would have to be for the system to work - then you also know your answer...)
Old Apr 5, 2024 | 04:18 AM
Originally Posted by Guitar_Tech
..... Do I assume that any spares needed will be for a 2008 model? ......
As no one seems to know I'll take the chance and where there is a choice, I'll go for the later (2008 and onward) recommended item......
I read a lot of posts and therefore cannot remember every member's Location or Vehicle details. It doesn't help when these don't appear in your profile so I've added them for you.
Never assume with a Jaguar - it will bite you.
Looking up your VIN in the decode confirms the vehicle is a 2008 Model Year:
The new Model Year is usually introduced around September which is why a 2008MY can actually have been built and sold in 2007.
This extract from JEPC (Jaguar Electronic Parts Catalogue) shows the VIN ranges for cable updates:
The rotating arrows indicate a part number is superseded so C2S48928 will fit all years.
I suspect the reason for difference in cable lengths is the original was found to be too short and therefore binding or not allowing the interior handle to return fully to the closed position.
Old Apr 5, 2024 | 02:11 PM
Many thanks for that, much appreciated.
I've expanded the Sig so there's (hopefully) no confusion.
G
Old Apr 5, 2024 | 02:44 PM
Originally Posted by Peter_of_Australia
Other than thet:
I was hoping to get the parts before stripping the old parts out as it is still sort of working at present and I don't want to disturb it and end up with a load of broken bits and a door I can't open any more.
G
Old Apr 6, 2024 | 12:04 AM
h2o2steam's Avatar
G,
Check out Trademe, as often there is a rolling advert for various model Jags that are being parted out if you are looking for second hand options- usually the seller is showing as located in Christchurch.
Old Apr 6, 2024 | 04:08 AM
Cheers for that.
G
Old Apr 6, 2024 | 01:49 PM
..... I've expanded the Sig so there's (hopefully) no confusion. .....
You missed your hat size.
Old Apr 7, 2024 | 01:46 AM
Dell Gailey's Avatar
@GGG I knew I forgot something, lol!!
Excalibur2012
Apr 8, 2022 08:45 AM
ericisback
E type ( XK-E )
Nov 18, 2021 12:28 PM
Stuart S
Feb 18, 2019 09:38 PM
Sheila
XK120 XK140 XK150
Apr 25, 2018 08:47 AM
gdw35
Mar 23, 2015 06:37 AM
