My car is dead
Old Sep 15, 2018 | 08:56 AM
Luke Farrell's Avatar
Exclamation My car is dead
Today I was driving and there was a slight hesitation and loss of power and a second later the power came back with a big puff of black smoke.... I thought it might be the egr playing up a bit but an hour late I lost all acceleration and had to pull in , now my car won't accelerate and even if I get it to barely move it cuts out completely.... My injectors are bad too , all 4 could do with a change... Also when I put the accelerator down to take off I could hear a strange scrape type noise... Does anyone know how bad this problem is? Is it even worth fixing
Old Sep 15, 2018 | 01:58 PM
Steve M's Avatar
Try and get the fault codes read; at least it will give you a starting point.
How do you know that your injectors are bad?
Old Sep 15, 2018 | 03:03 PM
i got a diagnostic test done and no fault codes came up.
I know they are bad because i had a leak test done and all of them failed pretty badly.
it looks like now i either get my injectors refurbished or ill have to get 4 brand new ones, the injectors are so bad now the car is undrivable. if i attempted to drive if it actually moved then a huge cloud of smoke comes out. this is from the unburnt diesel
Old Sep 15, 2018 | 03:38 PM
iownme's Avatar
one of the problems with machines is that they tend not to work as expected with broken parts
no matter how hard i try to mow the grass...that damned mower insists i use a sharp blade!
Old Sep 15, 2018 | 03:43 PM
NBCat's Avatar
Has anyone tested the pump pressure and checked the pump timing?
You might also post your question on the UK/Eire forum as most members here are from North America. Jaguar never sold a diesel variant of the X400 in North America.
Old Sep 17, 2018 | 03:24 PM
The pump is fine and has been tested and the fuel is free from any metal.
Old Sep 17, 2018 | 07:51 PM
car5car's Avatar
This is what happened to me 5 days ago:
I was checking transmission fluid level (not a Jaguar) and heard scrape noise. I used my "X-ray superman vision" and decided that it was camshaft bearing going bad. ( V8 pushrod engine). I added 1 pint of ATF-3, noise stopped in 20 sec., I drove about 100 miles to wherever I was going and then changed oil. I believe oil delivery hole was clogged and ATF fixed it. I have to admit, oil was pretty dirty.
car5car
May 5, 2017 09:31 AM
firstxf
Mar 14, 2013 05:45 PM
supraman
Jul 17, 2011 11:14 PM
MA
Oct 19, 2008 05:03 PM
boonchie
Apr 27, 2008 08:11 AM
