Name this hose
Old Jul 23, 2012 | 11:24 AM
konshu's Avatar
Default Name this hose
Hello all, I'm coming back to the huddle to ask for help finding the name of this hose on my 2003 x-type. The hose comes from the t-fitting between the coolant resevoir & the water distribution pipe that is under the intake manifold(I'm assuming). The hose in question runs under the car but I can't see where it goes. It now has a hole in it & I need a new one ASAP. I have included a pic showing the hose in question unattached.
Old Jul 24, 2012 | 10:29 AM
kccode1's Avatar
Well we used to just call it a radiator hose.
Old Jul 24, 2012 | 01:16 PM
konshu's Avatar
that goes under the car back toward the rear wheels? radiator hose?
Old Jul 24, 2012 | 02:39 PM
kccode1's Avatar
You didn't say that it went toward the rear wheels. You just said it ran under the car.
Old Jul 24, 2012 | 02:41 PM
MRomanik's Avatar
Veteran: Air Force
That is what it looks like to me as well.
File Type: pdf
Old Jul 24, 2012 | 03:29 PM
astromorg's Avatar
It's the return hose from the heater to the main cooling system. It doesn't go under the car, it comes from the firewall.
Old Jul 25, 2012 | 09:33 AM
konshu's Avatar
thanks astro, is this an r&r for an afternoon or a weekend? does anyone have a part #?
Old Jul 25, 2012 | 10:52 AM
Aonsaithya's Avatar
Bros before hose!
I could help you find the part number with JEPC if I had any idea where to look at.
EDIT: this any use?
Old Jul 25, 2012 | 01:26 PM
konshu's Avatar
Originally Posted by Aonsaithya
Bros before hose!
EDIT: this any use?
thanks bro. anything helps at this point
Old Jul 26, 2012 | 09:54 PM
konshu's Avatar
thanks fellas for all the help. I just went down to the parts store,got a piece of hose and a connector,fabricated a new return hose,now I'm back on the road
Old Jul 26, 2012 | 11:24 PM
Aonsaithya's Avatar
Good thing! Looking at that .gif though your suspension may need a bit of work
Old Jun 25, 2013 | 09:00 AM
afonda's Avatar
Is the "return hose" also the "outlet hose"?
URO Parts C2S5378 Heater Hose Outlet : Amazon.com : Automotive URO Parts C2S5378 Heater Hose Outlet : Amazon.com : Automotive
Found this on Rock Auto and Amazon.com...
Thanks,
Andy
Old Jun 25, 2013 | 09:17 AM
Thanks,
Andy
Item 3 (Inlet) and Item 4 (Outlet) have different Part Numbers in the Jaguar EPC:
Click on the image to enlarge it.
Old Nov 21, 2013 | 07:29 PM
gtoner's Avatar
If you fabed a new hose, did you run it from the heater core outlet down at the bottom of the firewall? if so, how did you get at the core outlet pipes as the appear inaccessible to me?
regards,
Gene
Old Jun 9, 2017 | 09:46 AM
mbald417's Avatar
Default can someone tell me what is this part
been looking for this part dealer can't find it with out a number
Attached Thumbnails Name this hose-20170609_092940.jpg   Name this hose-20170609_092944.jpg   Name this hose-20170609_092946.jpg   Name this hose-20170609_092954.jpg
Old Jun 10, 2017 | 03:30 PM
new mexico's Avatar
Default Hoses
Look up carid.com or 1 888 577 6964 for any hose.
Walter
Pristine97XK8Convertible
Mar 5, 2025 10:32 AM
mikiep
Dec 20, 2019 07:37 PM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
Lubrication
Oct 1, 2015 03:56 AM
