need certain parts
Old Mar 9, 2010 | 03:57 PM
Disco stu55's Avatar
Default need certain parts
Well, now that its finally warm out side, its only like -4 now an days. i can start working on the car.
I need a new wheel arch liner, a new rim, i want to do HIDS, and a new sound system ONE with a cd player, should i buy the player from ebay, or just forget it, and the acm,does it have good sound quality.
The wheel arch liner, and rim are prority, the belt is fudged int he spare, and i need that asp.
Where on the rim, does it say its size.
Whee can i get these two parts for cheap.
Old Mar 11, 2010 | 04:57 PM
Anybody out there?
Old Mar 11, 2010 | 05:40 PM
Alfadude's Avatar
Disco, do you just want to replace the stock wheel you had on there with another one? If that is the case there are a ton of remanufactured wheel places out there if you do a little searching. Should be pretty easy to find and probably less than $100 US.
Wheel arch, do a search of places that part out cars or Craigslist. Would thin that wouldn't be that hard to find used if you do some searching on the internet. Can get to be a pain in the **** sometimes, but it sure beats paying full price.
Old Mar 11, 2010 | 06:29 PM
Thermo's Avatar
Veteran: Navy
Disco, most rims are not marked with their size. You can figure out the rim height by simply looking at your tires and if you look, your tires will say something like 225/45R17. The "R17" is saying that your rims are 17 inches in diameter. If you still have the stock rims, then let me know which diameter rim you have and we can go from there as the stock rims are more than likely 7" wide as I recall.
If you have something different, then what you will need to do is get the tire off of the rim and then measure the inside of the lips from side to side and see what they say. That will tell you the rim width. For the most part, rims are measured in english units, not metric. Go figure. One of the last things to still be english. As for rim height, the best thing is to look at the tire. But if in doubt, measure the rim at the bottom edge of the lip and measure the circumference of the rim, then using the diameter of a circle, you can work out the rim diameter that way.
Old Mar 11, 2010 | 10:43 PM
yea i just want a stock wheel, ill measure it tommoorrow,
alfadude - anywebsite for remanded wheels, preferably one tha toffers a warranty
Old Mar 12, 2010 | 09:29 AM
nalleyjagparts's Avatar
Former Sponsor
Disco, are you in the States? We carry all that stuff at a discounted rate for US-based Jag Forums members. Email me if interested.
Old Mar 12, 2010 | 11:11 AM
IrishXtype's Avatar
Disco..is the belt your talking about the sepintine belt?Are you thinking of doing it yourself?If ya do let me know how it went for ya....And are'nt you in T.O?
Old Mar 12, 2010 | 01:29 PM
Not the serpintine belt, then belt with in a tire, its fudged and completely messing with my sterring, which i had fixed a month ago.
naelley, does that work for canadains tooo?
Old Mar 12, 2010 | 01:42 PM
Former Sponsor
Sorry, we only ship within the US. Sounds like you need to get your car a tire shop!
Old Mar 13, 2010 | 11:04 AM
Alfadude's Avatar
Disco, here are a couple sites I found after doing a quick search. There are a ton though if you look. Warranties vary and other than if there is a problem with the finish can't say how much good a warranty might be. If you hit a really big pothole or hit a curb they could say it's operator abuse. Or it might cost an arm and a leg to ship it back and forth. They aren''t that expensive.
http://www.wheels-and-rims.com/cgi-b...item1c10d93639
Scott B
Oct 24, 2015 01:29 PM
wardo5757
Sep 11, 2015 11:31 AM
jaggermang
Sep 8, 2015 07:07 PM
DAN L
Sep 8, 2015 07:21 AM
1100me
Sep 7, 2015 06:26 AM
