Need some Help with Vacuum Lines
Old Apr 3, 2019 | 03:28 AM
Chris Bonner's Avatar
Default Need some Help with Vacuum Lines
Hi all,
I just replaced a clutch in my X type jag. However I took so long to do it I forgot where a few Items go. Does anybody have a vacuum line diagram, I looked all though the manual but can’t seem to find one.
1 Is the vacuum line that T's from the intake manifold to the brake booster?
T That the vacuum line come off of.
Vacuum Line
Old May 20, 2019 | 07:33 AM
Anybody have any thoughts on where this might go? I have googled it and used the searched this and other forums. It seems other X types do not have the T.
2004 X type UK model
Old May 21, 2019 | 04:58 PM
JaguarBruce's Avatar
Down below the headlights just behind them is an ending point to connect that vacuum line onto. Right side from front looking at engine. There should be two ending points there.
Old May 22, 2019 | 03:51 AM
Thanks for the help! I had taken pic of the engine compartment before starting the project and in the pics it looks as if the line does route towards the front but was unsure why a vacuum line would go up there.
Old Sep 12, 2019 | 04:00 AM
What does the vacuum line supply vacuum too? I have looked around the head light area but can’t find anything that jumps out at me. I’m almost done with this project, car started fine and runs good at idle, clutch seems to be working and the trans shifts through the gears ok. Will road test it soon to get a real feel for the car.
mirisisa
Dec 18, 2019 09:13 AM
muttony
Jul 29, 2019 11:14 AM
willy574
Dec 15, 2018 06:31 PM
91xj6owner
XJ40 ( XJ81 )
Dec 22, 2010 12:27 PM
fall4it
XJ40 ( XJ81 )
Sep 13, 2009 03:13 AM
