Noisy tappets
The X-Type engines are of the Overhead Cam design and as such do not have lifters. The cams are mounted directly above the valves. It is unusual to have have cam/valve rattling without some other condition creating it. Miracle additives are just that a miracle if they help.
When did it start making noise?
What occurred before the noise started?
Has the engine been overheated?
It would also be helpful to engine size and type.
Mikey (04-07-2019)
this is Kawasaki tool for shim replacement. You stick it between camshaft and lifter, pushing lifter down to replace shim. Make sure piston is down, lobe up.
https://www.ebay.com/itm/OEM-KAWASAK....c100005.m1851
I can't remember when the noise started but it has been there over 4 months ,
The car was never over heated , it has been over cooled if anything as my thermostats were giving me problems until I replaced both of them , they were keeping the engine to cool.
It's a 2litre diesel,
She still drives normal, I would rather have my car a little quieter tho.
Luke thanks for getting back to us. The added information makes a difference in the response. All of the information I have provided so far is based on the petrol engine. You engine doesn't have the tappet and shim arrangement shown in my previous post. Below is the correct information for your engine. As you can see the rocker arm rides directly against the camshaft on one side and the valve on the other side.
I was unable to find anything about rocker arm adjustment in the engine manual. As such I don't know if the rocker pin point on one side can be adjusted. I would have my doubts. Most likely the best you can do is a visual inspection for any damage to the rocker arms individually or to the rollers on the rocker arms. You can attempt to get a rocker clearance reading to determine if one or more is considerably worn as compared to the majority.
One last thought is you might want to get a stethoscope and try to determine if the rattle is actually from the cam area or if it is from the timing change area. There are 2 tensioners on the chain that can fail and cause the chain to rattle.
Good luck with you endeavors and let us know how it works out.
+1 on the stethoscope
Possible timing chain guides noise
Found this old post from a Jag Tech in 2009 =
When the cars been sitting long enough that you think it will make its noise do this. Right after startup while the rattle is happening give the throttle a quick rap to 2000 rpm or so and see if the noise instantly goes away. If it does the VVT units are suspect. Not common but there is a VIN range with this potential problem not listed in any service bulletin.
VTSummit
E type ( XK-E )
10-03-2016 07:23 PM
