Normal for EGR to leak during smoke test? Pics added
Old Jul 26, 2014 | 02:48 AM
03Xtype's Avatar
Default Normal for EGR to leak during smoke test? Pics added
On a 2004 XJ8. Smoke test in search of a vacuum leak.
I know its normal for the EGR to leak on some vehicles. Is it normal for this Jaguar EGR to leak inside the plastic top?
Old Jul 26, 2014 | 08:17 PM
03Xtype's Avatar
I smoke tested my other XJ8 and confirmed its normal for the EGR and throttle spring/shaft to leak.
Old Aug 31, 2014 | 11:11 PM
ServiceMasterD's Avatar
Have you analyzed your fuel trim data at idle? That will tell you if you need to pursue the smoke test...
If you've verified fuel trims are off at idle, check the rubber 'D" shaped seals along the seam of the intake plenum. That's one common place on the 4.2, as well as intake seals.
Any fault codes?
P0171, P0172 don't necessary indicate a lean condition, if that's what you're getting. Try driving it around the block while monitoring your fuel trims. If you get wacky readings at throttle positions 2, 3 or higher, you may need a MAF. Again, very common on those...
Old Dec 11, 2014 | 12:17 AM
randy43's Avatar
It is normal. The vent holes are there to allow the EGR valve to vent vacuum pressure, allowing it to modulate its position. With no power applied to the valve, it defaults to the open position. If you tried running the smoke test again, but with the key in the on position, the vent should be closed on a properly functioning valve.
Old Dec 11, 2014 | 04:37 AM
JagV8's Avatar
I doubt that's right - may have been for some cars but not these I think. The PCM wants to be fully in charge of what goes where and no leaks at all. Leaks are what foul the fuel trims and then P0171/P0174 codes flag if no specific EGR code.
Any Jaguar master tech chime in...
Kevin Burnaby
Jun 28, 2020 08:04 AM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
Dymaxxion
Sep 4, 2015 02:40 PM
XFR_Gold
Sep 2, 2015 12:24 PM
