O2 sensor wiring diagram ??
Old Nov 22, 2014 | 07:32 PM
myexcursion's Avatar
Default O2 sensor wiring diagram ??
Would anyone happen to know or can show what the wiring for the downstream o2 sensor is ? I think it's the following , but not certain -
O2 Sensor - O2 Connector Socket in engine bay
Black - Blue = Heater
Black - White with Green stripe = Heater
Blue - Brownish green color = Signal
White - White = Ground
Old Nov 23, 2014 | 08:58 AM
Thermo's Avatar
Veteran: Navy
excursion, looking at the diagrams, this is what I am seeing as far as what the vehicle side of the wiring is (doesn't list what the sensor side is as that can vary from manufacture to manufacturer): Please note that the items in the parenthesis are for bank 2 and those outside are either for Bank 1 only or apply to both banks.
Pin 1: Blue (Blue with yellow stripe): heater ground
Pin 2: White-Green (White-red): Heater power
Pin 3: White: lamda sensor ground
Pin 4: Brown: Signal wire
Old Nov 23, 2014 | 11:29 AM
Exactly what I needed -- Thermo to the rescue
Thanks a million !
Old Mar 16, 2020 | 05:18 AM
Cris Ridgway's Avatar
Default 03 x type 2.5 wiring colour codes for all 4 o2 sensors. For correct connection. No p
Wiring diagram. Color codes for o2 sensors. No plugs. Only lose wiring. Want to wire up bank 1.up ad down. Bank 2.up ad down. correctly. Your help be great full
Old Mar 16, 2020 | 05:40 AM
Thermo's Avatar
Veteran: Navy
Cris, not to question what you bought, but from our experience on the forums here, if you have O2 sensors with no pre-fabricated plugs on the end, you are going to most likely have tons of issues. Yes, they are cheaper than the others, but for some reason, they just don't work so well inside of our Jags. Can you make them work, you might get lucky. But, I think you are going to find that spending a few extra dollars is going to be well worth a lot of your time.
Old Mar 16, 2020 | 04:24 PM
Just need to know which wire goes to what senor. Ad there colours codes.. Wiring info on bank1. Up ad down. O2 senor. Ad bank 2 up ad down o2 senor. So i get wiring connection correctly.. So no faults. When connected to obd2 scanner..
Wiring Colour codes. To the 4 o2 senors. Please.
for bank 1. o2. Up stream.. Ad bank 1. o2 down stream. Senors.
Wiring codes.
For bank 2. o2. up stream. Ad bank2. o2. down stream senors.
Old Mar 16, 2020 | 07:02 PM
clyons's Avatar
for bank 1. o2. Up stream..Ad bank 1. o2 down stream. Senors.
Wiring codes.
Old Mar 17, 2020 | 05:56 AM
​​​​​​. Theres no connecters. Male or female connection. Plugs. Connecters remove.. Just wanted to know what wire connects to what o2. Or heater. Signal... 4x senors. 4xwires per o2 sensor. 16x wires. Want there colours ad function. 12v.signal.earth.heater....
Old Mar 24, 2020 | 09:59 PM
Originally Posted by clyons
Thank u.
Im swt.. Now
ya bloods worth bottling. SIR
etaent
Aug 30, 2018 11:32 AM
car5car
Jan 29, 2016 11:29 AM
Delbert
Feb 13, 2013 08:13 PM
Fezz
Oct 20, 2012 12:45 PM
xtypelove
Jan 24, 2012 11:31 AM
